Turbo Upgrade
[PIMPIN]
Well, it seems like circumstances surrounding my car have resulted in me needing to look at my turbo set-up. When the engine blew last year, bits and pieces of the engine flew out the exhaust (via turbos) and during the rebuild, I inspected the turbos and sure enough they were on their way out. However, they were strong enough for the low-boost running-in of the engine so I left them there.
Now that the engine has been fully run-in, I sent the car in for service and again, took everything apart and sure enough, the turbos are ready to call it a day. It's good that they managed to last during the run-in.
So my options so far are as follows:
1) Use the existing turbo setup (GT-RS) but new ones.
2) Go for a single turbo setup (GT35R or GT4088r).
The thing is, I'm somewhat attached to the current setup and since I have yet to fully experience the GT-RS with a 2.8 engine, I feel it would be a waste to go for a single turbo immediately. It seems that the GT-RS and the 2.8 engine work well together and having experienced them with a 2.6, I'm keen to see how the torque helps the car really pull out of corners cause previously its been laggy.
If I were to go for a single turbo set-up, the GT35 seems like a good choice provided I don't make the mistake of opting for the smaller exhaust housing which I believe chokes the engine. The GT4088r is also a good idea or even a GT42 but then again, lag is a huge factor hence its unlikely at this stage. Plus, the 264 cams would probably need to make way for 272s I reckon.
Anyways, I have decided to remove the stereo install in favor of a custom fuel system (considering a RIPS setup) but I'd stop short of changing cams AGAIN.
So my questions are:
1) Should I retain the GT-RS combo and be happy with the 600hp or so.
2) Go for a big single turbo setup since the HKS Step II is built for 800hp anyways. Bear in mind this would probably require new cams.
In both cases, the fuel system will of course be upgraded. I'm leaning towards a 3L surge tank, based on an estimated 1.5L of fuel per 400m drag so double seems safe or should I go bigger? I know RIPS do bigger and would prefer bigger surge tanks but the thought of having too much fuel makes me uneasy.
Comments?
browsed through the net and found that brand new 2x GTRS (RHDJapan) cost USD3600. GT35R costs as much as USD1500.
as from my point of view, going single needs to redo quite so much. The exhaust header and downpipe and also wastegate too am I right? Also, you mentioned you'll have to go for 272 cams if were going single. HKS 272 8.7 requires no swapping of valve springs but 10 and higher does. 2 cam stick around AUD1000. There goes the money again. Labour cost too.
if you are not satisfied with the power right now, by all means go single. :biggrin: I know you can afford it.
But if you are satisfied with the power, replace the GTRS pun cukup. Besides, you havent fully experienced the new setup riight? :biggrin:
Bro,
Thanks alot for the price comparisons and pointing out the various 'hidden costs'. As I think about it, the more I'm inclined to keep the GT-RS since as I've yet to experience it fully thus I wouldn't be able to say if its enough to keep me happy.
I think the logical step would be to retain the GT-RS setup, new ones, and see how it goes maxxed out. If its not enough then upgrade and sell off the GT-RS turbos.
Plus, need money for the 35. Hahah nah kidding.
With a 2.8, I'd try Garrett TO4Z....
Inline six is special that it's very easy to use single turbo setup.
Not like V6 or V8.
err you at in decision between GTRS and GT35 Single
my suggestion is in between GT30 turbo but TWIN
GT3071R
but not sure the turbo can clear the engine bay and bonet or not
hehehe
wah lau.
hmm, too much technicality. but pimpin, do u prefer a smooth rise in power(twins) or just a kick in the nuts(big single turbine)?
Should have gone with 10.5:1 custom compression pistons ... 1st N/A GTR wor ... :rolleyes:
Sorry ... just a suggestion :driver:
huh? what? NA RB26?
Handles like holden? LoL
can't believe i'm reading this. haha
hmm, on the other hand, suggest to top secret la. they might just do it. and place the rb in a silvia. hehe
I'm sorry but going N/A for a RB engine is utter heresy! :confused:
Might as well join the VTEC brigade.
Atmospheric engines just don't make much power unless the displacement is big enough.
For me, the minimum for a N/A engine would be 3.2L eg. S54,VQ35,LS-series etc...
Not sure who did, but there are some aftermerket custom pistons (10.5) floating around in australasia and europe region ... :listen:
N/A GTR ... :rofl::rofl::rofl:
[PIMPIN];3530923 said:
Didn't Autech (sp) build an RB26DE before?
YES ... they did and it is very limited ... some tuner did tweak it by amongst others putting 6 independent trumpets ... awesome god-of-war kinda sound
i would suggest a single T04Z. not too big, not too small. 600whp easy peasy with supreme response.
that's the turbo i would buy if i had the money. abg razaksa, pls chime in to give ur feedback(dont just lurk around contacting people via PM only :P). ur using the non-ball bearing version of T04Z... surely u have something to say about this turbo hehehe
