how u do it.
keep ur engine running.
hold the candle in aplce then put the candle body to rub wtih the belt.give a little bit of pressure to the belt. the candle body will melt cause of friction and heat.
so actually this noise problems is caused by loosen belt or its too tight ?? cos i read some post up there which said tightening the belt and some pulak put grease, arent applying grease will make the belt more licin?
aiyaaa...check the belt tension...maybe too loose...retighthen it...can DIY what...but becareful, got to know the exact tension...
too tight...will 'putus'
too loose...willl eeeeeekkkk sound
Don't use oil on the belt. There's friction on the belt for a reason. To rotate the pulleys. Go to the mechanic to tighten or to change the belt. Belt dressings work for a month or two but I suggest it changed as it might break.
Oh, it's not a timing belt. Prolly a alternator, fan or power steering.....
still contemplating on whether to get a GTT to replace my current daily driven car.... was wondering, how many are you guys using a GTT as daily driven car, and any problems with your car?
