DeOngster said:bro the td04l from a wrx is a bigger turbine than the td04l from a gsr... the wrx one produces more power with minimal lag [tested and proven in uk, with the wrx u can easily reach 220bhp in a 4efte of course with some other mods]... im getting mine done will show you once completed... cheers
normality78 said:i not sure but u dun think repair TD04 would be wise in terms of costing as i think repair it will anytime come close or even higher cost thn getting another unit
alvin24 said:WRX uses IHI turbines ma no meh? =Þ
If you get the STi version's turbo... its ball bearing (correct me if i'm wrong). SHould do heaps on cutting down turbo lag.
normality78 said:bro, do u have the exact td04l model no frm WRX?
ModMaestro said:Hi,
I'm using a TD04L(hybrid 18G) on a 2.5 10 valves Volvo.
Boost about 0.8 bar, 240ish. Power range is between 2000 to 5000 RPM. Seems to hit a ceiling at 5000, should be because I'm still using the autobox.
ModMaestro said:xtremeleo,
yeah my mech says I can squeeze more power if I go up the trim although I don't actually go pass 5k that often. but anyway to increase my torque?
