chocolatesttarfish:
sorry for didn't explain clearly on the previous post...my eng not really well...
not the rotor surface or the brake pad friction surface...just apply the grease at the brake pad backing plate surface where the anti-squeal shim will be attach...but applying grease just a temporary solution,the squealing sound might be come back again...anyway,try to replace the anti-squeal shim 1st...sometimes,the squealing sound might cause by the brake pad too...the friction compound doesn't mix well enough...
oh ya,regarding the disc rotor surface cleaning...can use some thinner to wipe the surface of the disc rotor...^^
