SMT6
heheh... :P
all are juz as good...alot depends on the tuner...
itz how they optimise the full facilities and functions in each ECU.... ;)
Toby will install a Haltech 3 bar map sensor for your SMT6 install if you're running a turbo. The SMT6 picks / uses the manifold pressure for tuning purpuses. For n/a tps will do. Good thing is that this is included in his installation and pricing and IMHO a good piggy but its only as good as its tuner. GT has a Dyno on the spot for tuning after install.
Jack
With the 3bar map sensor, does tat mean u can do away with the OE maf sensor?
Jo, no the car still use back the MAF. Its like this
MAF --> ECU --> SMT6 (with MAP sensor) ---> Engine.
The MAP is installed to take the boost readings for tuning. If you have a boost meter or controller that have an external sensor. Toby can see if he can tap that, then save on buying the MAP sensor lor... with the 3bar MAP sensor, can upgrade to Haltech anytime mah!! hahahah ^_^
Yea
RM500 is cheap for someone le and vice versa
but for someone who talking about 3 BAR map sensor on SMT6 mean expensive
but for someone who talk about 3 BAR map sensor on E6K or X mean murah gilo
my friend's supra, he using E11, he bought 6 bar map sensor .. :o talk about high boost !
Nick... I know this friend of yours la... he drives a black Supra with VR rims right?
the black monstarrrr
sdf,
With SMT7, is it possible to remove the existing MAF? This assumes you will need to buy the MAP sensor right?
SMT-6 or 7 comes with a 3bar MAP sensor...
but u can't remove the MAF sensor... ;) but don worry...it will be in good hands...hehe...
Darn it... always wanted to use the APEXi air filter (funnel type) but the stock MAF is in the way. :(
can get adaptor ma....i sold mine to Eclipse...stainless steel finishing...
i go chk wit my fren later...i ring u...cheap cheap only... ;)
if got money go for second haltech.around 2.5k-2.8k.but inculude install and setting should be around 4.5 :ph34r:
guys....between smt,unichip and e-damage which one got more feature and function?
yeah i know everything also depends on tuner but just wanna ask only.tq
can u guys state the price plus install and setting for those 3?tq
Hahaha... e-damage? Enough to scare everyone away... :lol:
