Try YS Khong Motorsports.opp1 said:Badgti ,
Thanks for the update. Called Toby today and he said that he is not selling the SMT 6 anymore. Humm..anywhere in kl where Ican get one?
monsterv6 said:sure or not haltech interceptor does not cost rm5k.?
Boink Boink said:Just wanted to clarify, piggybacks and stand alones are TWO different things.
A Haltech 6 can make my semi-batch fire iginition to fully independant batch fire iginition. Thats a whole load of difference already ler.
Also stand alone ECUs offer a whole lot more ability. Best understanding is that a piggy back can only trick the original ECU to a limit before the ECU starts saying, "Now there cant be THAT MUCH air flow in at the air flow meter."
brother said:need some help....did the smt6 same like haltech no need to conect to ecu?coz i found a engine dun have ecu the engine is e15et turbo spec.no ecu coz the engine is very old than malaysia dun have sunny 130y is using injection so how? if i convert this engine to my car. :albertein
Think you need to do some research first. If you visited the manufacturer's website you will quite obviously realise the SMT6 is a piggyback ECU. Not to mention the posts here.brother said:need some help....did the smt6 same like haltech no need to conect to ecu?coz i found a engine dun have ecu the engine is e15et turbo spec.no ecu coz the engine is very old than malaysia dun have sunny 130y is using injection so how? if i convert this engine to my car. :albertein
if fit in microtech and haltech so expensive la so if can try i will do hybrid some other 4g15p ecu lo....so where can modify this thing???140dB said:hi,
wow big project ahead. good luck.
u need a stand alone ecu if i get what u trying to say...
look for microtech, haltech or maybe even perfect power PRS???
if ur mech really got time..heheh ask him hybrid some other car ecu into ur car...
4g13p and 15p berlambak...can try..heheh
again, good luck..
140dB
thank speed domon jsut now i noe wat is piggyback tk....Speed Demon said:Think you need to do some research first. If you visited the manufacturer's website you will quite obviously realise the SMT6 is a piggyback ECU. Not to mention the posts here.
Piggyback ECU means it works TOGETHER with the original ECU. So if you don't have one....
"map sensors can be installed which i guess provides fuelling data independant of host ecu."140dB said:hi boink,
IMHO
if u afraid of insufficient fuelling, newer piggybacks like smt6 besides being able to drive bigger injectors, they can also drive extra injectors. map sensors can be installed which i guess provides fuelling data independant of host ecu.
of course a fully s/a ecu is be$t no doubt
pls correct me if wrong guys...
140dB
