How much increment of power? This is very subjective.
with 4 throttle and without the restriction of air flow from plenum cover, definitely you get more air in your engine which is good for combustion but, do you have enough fuel? This normally happen when you utilize stock ECU with open plenum, you'll face slight hesitation on the acceleration. Imagine the sudden air surge into engine when you accelerate 20V engine, the AFR will become very lean for a second or two, that is the hesitation point, then it will continue to accelerate as normal.
You definitely don't want this condition happen when you going for 400m spin because it can kill you initial momentum. Solve the slight hesitation and you'll get real power increment.
