1JZGE(NA) ITB 6 throttle from BT20V,Can it Be Done?
skmasterhian
Penang/pahang
Happy thursday zthians :wavey:...Im looking into getting a 1JZ engine for my car,and it seems that 1JZ turbos are way to scary for me, and im looking into getting a vvti 1JZGE(NA),and i had this idea :idea: where it would have 6 throttles(ITB) from the 4age 20V blacktop(buy 2 sets of throttle..cut one in half 2 throttle+4throttle=6 throttle )
is it possible with the right amount of money?
has anyone done this before?
and how will the MAP sensor work with this new set up?
feel free to share your opinions?
:driver:
this project is interesting..
i've seen BT 4 throttle on Honda B16..
i think it can be done.. just need money and patient
after all, it's just metal parts :biggrin:
---------- Post added at 03:12 PM ---------- 6 hour anti-bump limit - Previous post was at 02:57 PM ----------
My suggestion is cut d 1st & 4th throttle and put it at both side of d trottle u wanna put in ur car
So that the throttle body sit in d center of those 6 throttle :wink:
my views...:itsme:
- you might need standalone ecu
- throttle linkages - need good machinery to fabricate, so throttle open for all 6 are balance
possibly the idling would be better compared to 4throttle...
Can but you need to sort out tuning issues..Jaspal Motorsport has a 2jz with 6 throttle setup..if you are interested pm me will provide you with his num
We can do custom design & fabrication of aluminum adapter to mount individual throttle body.
Using CAD & CNC precision machining method. Give us a call & ask for a quote for any of your custom made parts!!
[email protected] / 012-283-3635
wow looks like you're going the NA route... i believe it can be done... last time my kelisa also using 4 throttle from BT but of course minus one throttle... very nice sound but management is a pain in the butt!!! idling really bad...
read this before, i hope i'm not wrong...
requires a good management with few mappings reference...
like TPSvsRPM etc as MAP alone cannot due to vacuum... i think...:confused:
Yes can be done,however if the engine is using Airflow (i believe 1jz vvti n/a is using airflow),you need a aftermarket ecu (standalone) to control it using MAP sensor,or you need to custom made an intake plenum to fit the airflow meter before the 6 throttles if you want to run stock ecu.
In Malaysia You can do anything you want, as long as you have the money...hehehe:biggrin:
good idea bro, note taken
my views...:itsme:
thank you bro,i will write this down.
Shark79. Is it Jaspal singhs workshop arr? in Seberang Prai,Penang Rite? sure i want his number thanks.:biggrin:
Cheeft just trying out my options bro,hopefully it will happen.thanks
that is going to take some tinkering and a really good workshop to sort this out.:biggrin:
that means i have to get a ecu like HKS fcon V? yup i am thinking of fabricating a custom intake plenum but this is the initial plan for this project,just have to get the money,and a willing mechanic to help me along with this project:biggrin:
p.s thanks you all for your support,and sorry for the late reply.:driver:
New Posts
