Just want to ask what you guys think about this sub? Is it good for SQ? How much different does it sound if compared to the seas lotus 12 sub?
Thanks!
Thanks!
Because I don't like how the JL sounds. To me it lacks definition in the upper bass...sounds so thick.
Hi Iswara,
How does the RS compare in terms of accuracy to other SQ subs that you've heard? This is going to be my reference system...so I really want it to sound very good.
Zenn,
I understand your point. I often cross mine below 50Hz with a steep slope. But in this system that I'll be building...I want it to sound dynamic. A high xover point helps augment where the midbass falls short. I like the Scan sub...my only problem with it is it's low sensitivity and it is output limited unless I run 2 of them. But 2 scans cost too much.
Tohsan,
As much as I'd like to try the Aliante...I couldn't get it from where I am.
Iswara,
Since you have the RS sub...can you confirm to me if the basket used is a cast basket? In the pictures it looks like a stamp steel basket. I'm much more inclined to purchase again the Seas sub since it looks like that it is built much better than the RS.
