Question for a Radiator
oh.. u mean if I use those kinda high pressure one...
it could be demage the radiator?
how much is the stock radiator cap? actually the
shop recommend me to get this one... I'm just little
confuse here... so fat that happen.. it doesn't happen anymore...
I just wonder why.. actually I just changed the radiator ...
the stock 0.9 radiator cap is freaking cheap only , about 5 bucks or maybe a better quality is around 15 bucks .
if wanna use those high pressure radiator cap's , make sure u have silicon hose all around and a high quality radiator like this one :lol: .
just to ask...for gsr engine..if i wanna to use aluminium radiator how much will cost me?
can i straight away use a bigger want? maybe if i gatal2 change to 2.0 cc?
hope u all can give me good answer..
cheers ;)
yb, if i'm not mistaken the 4g93 rad is the same as the 4g63 rad...
yes, you can order a alu rad from koyo, fidanza and others... it should be around USD200 - 300 excluding shipping and tax. The only local co that I no that does alu rad is FRC in sunway and lets say they are not cheap ... be prepared to weld some alu mounting for your fans as they come without the fan mounting... them tuner expecting you to use some custom industrial / performance, extra large fan mah ...
Write your reply...
