Force Performance said::shades_smile: U don't need 2 replace 2 d programmable type Ecu 2 advance d 20v timing. U can just rotate yr. distributor if u require more advance ignition.
Would b wonder what type of fuel u use? :shades_smile: If yr 20v mods really need that much ign. It means this engine having a very in-efficient combustion frame front.
It is definitely not the proper way of making power via advancing the static ignition mark from the distributor. You are merely shifting the entire ignition point up a few degrees throughout the rev range. You might have better mid range, but at some point, the ecu will detect knocking at peak rpm. Thats just the cheap but inappropriate way of making power. Ping might not be audible to human ears but piezo-sensors are pretty sensitive. But agreeable that these stock ecu have been "conservatively" mapped hence making power upgrades a great potential.
It cannot be merely stating that the engine has inefficient combustion flame front. If the 4age engine has very inefficient flame front, it would not be able to push another 20 to 30 horses easily from NA tuning on top of the stock condition. Flame front propagation is has to be identified whether in laminar or turbulent state, which then is affected by Pressure, Temperature, Composition of unburned gases, and Engine speed.
