Other MAP sensor for 4AGZE...?
1298
SABAH
Hi there! Does anyone know if there are other MAP sensors which can be used with 4AGTE setup using 4AGZE system?
Thanks in advance...
So that 4EFTE MAP is plug and play kah, bro? Able to read up to how many psi?
How's your fast car going? :)
4EFTE and 4AGZE is same, i plug and play both of them on my car before, nothing much different.....should be 0.9 is the maximum maybe only 0.88 or 0.87 already boost cut!!!
I see...lets say if I want to rise up the boost to around 18-20psi, instead of using the bleed valve to trick the ECU, is there any other MAP sensor I can use...?
dun use FCD la.. no good.. it will keep the signal to ecu is 0.9bar to avoid boost cut. easy to blew engine le if u dun have aditional injector tuned right
i will go for AFM for my 86 soon, i got the ecu and air flow already. juz no time to do it yet
Write your reply...
