Need to change 4age to 20v or 4agze! need some information
Sifus, since this thread is about the BT swap, I have a question for you. I bought a wreck which has a 4agze block in it but the previous owner installed a Peugeot carb instead of keeping it stock!!?? So its literally an engine kosong. Can I use swap a BT head on the 4agze block and run it as a 20v with the BT ecu? This way I don't have to change the engine number. Pls let me know if there's anything Else I need to consider. Thanks in advance.
if u already have a 4agze engine n wanna put BT head on it, u need :
- 20v piston
- BT ECU n wiring
but if i were u, i'd change d carb to 4 throttle n turbocharge it .. its a lot more fun :biggrin:
Thanks Dzul. The only reason is I wanted to keep the engine no. the same safe the hassle for registering again. If budget permits, yes I would go with a turbo setup...but the car restoration is a killer.:banghead:
