newly overhaulled engine...
ayil
30
i've jus finnished a complete overhaul of my engine and gearbox.. just wondering if i should wait 5000km after the run in before using tufoil??
i plan to immedietly use it in my gearbox..
FYI all the main bearings, piston rings, conrod bearings changed.
would appreciate any input..
Battousai
699
www.durifto.blogspot.com
do not use tufoil in your newly overhauled engine or gearbox
i repeat
in fact...
don't even use semi or fully synthetic. Just a normal mineral oil. Using any of the above will result in your engine not breaking in properly.
jinkl
4,623
376
3,183
confusing.. dunno wats being said hehe
ayil
30
my concern is that after a major overhaul you need to run in the engine (like when you buy a new car) this is to wear out the bearings until it fits snugly to the crank/conrod..
so i guess if tufoil is very slick.. then the bearings won't wear in properly.
but i think putting it in the gearbox staighaway would be ok.. no new bearings there..
FocalPoint
803
13
Newly overhauled engines tend to be tight like those straight out of showrooms. With new pistons and rings, it will be a good practice to wait till 10,000 km to use Tufoil so as to let the rings seat in perfectly.
However, we do come across many overhauled engines using Tufoil straightaway for their owners wouldn't want to miss out on Tufoil.
In the case of gearbox, you can use a mixture of 5% Tufoil.
ayil
30
would tufoil effect the performance of my LSD?
(clutch type LSD)
FocalPoint
803
13
For clutch type LSD, it may be too silppery. If you have to use it to solve a problem, use not more than 5%. We are thinking of 1 to 2 spoonful.
Care and Feeding of the Porsche Clutch
by Paul Lighthill
A recent call inquired about severe clutch chatter in a Carrera 2 that had only 30,000 miles on the odometer. It has been my experience during forty years of dealing with things mechanical that the operator is the single most important factor in determining a machines longevity and reliability. Perhaps nowhere is this more apparent than in the clutches and transmissions of our favorite cars, where PIO, or...
