Mythbusters = toilet pills
jiusan
helo all ,
i'am a super fans of the NatGeo MYTHBUSTERS ~
i watched them over and over again , then there is this episode where they test putting all sorts of stuff into an engine and also the fuel tank ,
well ... they did not strap it to a dyno ,but when they put moth balls / ubat gegat ? is that what its called ? the engine is like having some kinda boost ,
like someone just filled high octane fuel on the tank
< please note that it is the fuel tank i said not into the engine >
well , i believe when added with fuel the components inside this things actually gave improvements to the quality of the fuel thus when burned in the chamber giving extra boost ?
but not recommended to try it on daily vehicles thou as there are also materials on that thing when melted will disrupt the chamber as they dirty it right ?
and it is a very harmful chemical so when burned and out of exhaust you actually poisoned everyone around
someone post a thread like this long ago if not mistaken and i know somebody that race their bikes did so , but they overhaul the engine every single race so its no problem .. i think ...:biggrin:
other than that there are still 2T oil < motorbike lubricant to add on fuel tank that smooth those small bike engine internal movement so they don't blow >
that added to cars thay actually smooth en the valve movements and give more err smoother ride all the way ?
hahaha
big fan of mythbusters here! watched all the episodes mutliple times too...n yah there were a few threads bout naftalena n its effect on power. i believe it works but theres no free cake in this world. there's always an adverse effect n some of the bikers say theres a heavy carbon buildup after usage. maybe u can counter this by carbon cleaning yr engine more regularly?
hmm but its stil not that good even if we can wash it , coz we pollute others health badly ... like using leaded fuel and etc ...
Moth balls are Naphthalene, C10H8, a type of solid hydrocarbon. I'm not sure if they dissolve in organic solvent (petrol) or not. Its a volatile hydrocarbon, which is almost similar to our petrol. It will produce flammable vapor when exposed to air. I'm not surprised to know that it can actually boost your engine :)
pure nafatalena would help combustion but what are the side effects? will it leave any residue in the combustion chamber?
jiusan...dont go n put mothballs into yr petrol tank yet k? heheheh
hi guys, i have been use this since i bought my car. it really gives more power and saves fuel in a way. Been using this for more than 5 years and so far, there's no problem with it.
