Currently using this type of model (MTX-8) , just want know what the difference between RPM LIMIT and RPM CUT that got on the handset. Other thing is the boost limit at 25 PSI so if i just off the boost cut , will the ECU will be full function below the 25 PSI ? mean will be the fuel / ignition map will be use as per set after the state boost level ??
Thanks in advance ..
