So now we have established that my stock rims offset is +34mm and i still have 20mm of gap to the fender, so i need to look for rims with +14mm offset in order for the rims to be flushed with the fender?? Correct ah?![]()
Yup....
Got rims with this type of offset meh? Because most of the rims i see, is all like 30 plus or 40 plus.......Never see such a small figure before....
Got zero and minus even, but probably not with your PCD......![]()
All the rims i see is like big numbers. 30-40. I never come across 14 or close to this figure
Well......At this rate, i think using an adaptor seems to be the option that is shining....Hahahahahah
I think marv3 is using 4x108, so 4 lugs right?His is 5 lug. So if 5 lug go for 114.3 la. way more choice.
Sent from my Nexus 5 using Tapatalk
I am 4 lugs......So go for 100??
If use adaptor you can change your lugs to 4 or 5 lugs, then either 4 or 5 lugs they have rims 8 and 10 holes mah!.....plenty of choices.....lol![]()
Would such spacer causes vibration when the car driven?? The spacing of nut holes don't look spaced-out correctly....
Teik Ming sunway
