Lightweight Rims 4x108
30,002
So now we have established that my stock rims offset is +34mm and i still have 20mm of gap to the fender, so i need to look for rims with +14mm offset in order for the rims to be flushed with the fender?? Correct ah? :confused:
Yup....:driver:
marv3
496
57
Got rims with this type of offset meh? Because most of the rims i see, is all like 30 plus or 40 plus.......Never see such a small figure before....
30,002
Got zero and minus even, but probably not with your PCD......:smokin:
marv3
496
57
All the rims i see is like big numbers. 30-40. I never come across 14 or close to this figure :banghead:
Well......At this rate, i think using an adaptor seems to be the option that is shining....Hahahahahah
30,002
Use adaptor and change PCD to 114.3 or 100, plenty of rim choices....:driver:
marv3
496
57
If use adaptor you can change your lugs to 4 or 5 lugs, then either 4 or 5 lugs they have rims 8 and 10 holes mah!.....plenty of choices.....lol:rofl:
Can meh??? I thought the adaptor is only meant to change your PCD. But the lugs remain the same?? I was told by a rim shop. Say cannot change from 4 lugs to 5 lugs wor....
Can somebody please verify?:confused::confused:
30,002
Can one, see the machine shop skill loh!
Found one picture.....
30,002
Most machine shop should be ok. Just whether they willing to do or not only.
Even my suspension the mounting at the bottom was smaller, so mechanic ask machine shop to machine 2 pcs metal cup washer to fill up the gap
powerzone extractor 410
sportrims 2nd hand 550 (so call as avanti with tyres, but i dunno whether real or not)
i can change both 1 short but i dont wanna waste too much money just after CNY
