shazmi3, last time i sold it for rm280 la...since he sell for rm200, consider ok la..hw u know condition nt ok, u went there n check ka....as long as din crack ok la...condition nt nice can polish wan ma...i did mine last time, damn cun....hahahaha!
mcfurby i know i miss alot... guys, how much is the market value for front grill sprinter like this i saw desmond wanna sell at 200 but the cond not so nice, if the cond is nice how much?
SVT 20V on EE80 definitely need to mod the engine mounting. 3 out of 4 mounting will fit perfectly, but the right engine mount (near timing belt) need to be removed and brought forward. It has to be done perfectly as JPJ/Puspakom will check on this spot for any welding marks.
Fuel system also had to be changed and the main prob is the carburetor tank. You need an AE82 EFI tank (rare) or AE92 EFI tank. Easier and cheaper method is adding an external fuel pump (RM100), but fuel will cut off when taking sharp corners at high speed. Another method is to mod the existing carb tank by finding the right sized EFI fuel pump. Then, you need to add two more piping for fuel, one for fuel (to the fuel filter) and the other is for breather (to feed fuel "gas" back to engine).
I learnt a couple of things during my EE80 BT 20V swap (still in progress) and hope it helps. Also make sure your mech has done such conversion before, otherwise you will have a lot of headache!
Okay... so changing to EFI tank for LE is almost impossible as you need AE82 EFI tank, right? Some said AE92 EFI tank might fit, but I'm not too sure about it.bro, whether addin external pump or add in internal pump to ur existing carb tank, cornering still mati engine.
The secret is the efi tank design n not the pump. The avoid engine mati when tanke cornering u only hv 2 options.
Option 1: Change EFI tank
Option 2 : Put in a surge tank.
Originally Posted by...
