Hydrolocked Neo CPS now under going some internal mods
Imagine a mushroom under an umbrella, but the umbrella has a holes.
If your umbrella doesn't has holes, it's just fine.
The repaired crankcase wall
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs059.snc4/35299_138648566157720_100000377312513_250854_7656312_n.jpg
Short block, crank assembly and the piston assemblies
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs059.snc4/35299_138648569491053_100000377312513_250855_5713135_n.jpg
Crankshaft, conrods and pistons are installed back into the block. Notice the shiny area on the conrods (1, 3 & 4), due to lightening and balancing process
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs070.snc4/34860_138648722824371_100000377312513_250861_2200834_n.jpg
FEAD block and oil pump being assembled to the short block.
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs070.snc4/34860_138648729491037_100000377312513_250862_1949175_n.jpg
Flywheel. Skimmed at the back surface. Even the bolts are indexed in the balancing process
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs187.snc4/37698_138648989491011_100000377312513_250865_8118033_n.jpg
Back in to the engine bay
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs167.snc4/37698_138648992824344_100000377312513_250866_6809051_n.jpg
Installing the engine head
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs167.snc4/37698_138648996157677_100000377312513_250867_407603_n.jpg
Really nice build....when its done....I think I will make it a sticky....very good thread..
please do so...
---------- Post added at 05:24 PM ---------- 6 hour anti-bump limit - Previous post was at 05:23 PM ----------
any increase in hp? dyno result?
Thread sticked....Drex do share more info with us. TQ
please do so...
Dyno result will only be available after 1000km run-in period.
Anyway, very impressive response in the first 10km test run.
THESE ARE SOME PHOTOS TAKEN DURING THE EARLY STAGES OF DISASSEMBLING THE ENGINE.
Oil seals, bearings, piston rings, etc
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs147.snc4/36734_407913580747_595190747_4595986_31118_n.jpg
The new pistons
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs127.snc4/36734_407913595747_595190747_4595989_8131253_n.jpg
Piston & Connecting Rods, notice the snapped one
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs146.snc4/36686_407913900747_595190747_4596003_3326262_n.jpg
Stable vacuum level is a good sign for good compression and no abnormal leak over the piston rings.
http://sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs090.ash2/37833_138983006124276_100000377312513_251981_3904949_n.jpg
Water temperature after a series of hard running-in drive. Healthy.
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs190.snc4/37833_138983009457609_100000377312513_251982_4318805_n.jpg
Engine oil temperature after a series of hard running-in drive. Healthy.
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs190.snc4/37833_138983012790942_100000377312513_251983_2140691_n.jpg
Did about 40km so far. This was taken at exactly 20km from the 'resuscitation'.
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs190.snc4/37833_138983016124275_100000377312513_251984_6924711_n.jpg
Finally, discharged from the hospital.
http://sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs112.ash2/38963_138985996123977_100000377312513_251990_1874601_n.jpg
the `umbrella with hole` is mean vented bonnet? how much for the total repairing cost? need rm 5000++?
Exactly. Close to RM3k, excluding the new crankshaft. We didn't use back the old crankshaft because it was slightly bent (by ~0.1mm). It's still useful, but we just don't like the idea of having defect in a newly rebuilt engine. Long term reliability is always in our philosophy.
u mean to say the fiber hood the owner using is not good enough the water flow below that's why water come in?wah like this must be careful when buying vented hood,later air masuk,anyway,is a very good project that everyone can share and know.
rm3000 oni. consider cheap. how about labour charge? 0.1mm, how to measure? now is rainning season, for who have CAI, pls be careful
nice thread..but it gives me some creeps watching the hole and snapped rod. might consider to re-route my CAI
