How to improve low end speed?
First u better try use Motul Synergie 6100 engine oil. At least 10% low-end improvement is there. Tried it.
whoaaa,... straight send?
good!
eh, jin,... guang dao also good,...
guang dao good onot, i'm not really sure, coz lot of bad impressive bout those China & TW product...
Ok i will pm u my details.
ok...
my b16a already got e-manage blue with ignition harness installed...can i oso put in hks twin power?is there any significant power gain and can they work together?
sure can, coz twin power is act like power booster/amplifier only...
atleast can get 3whp...
bro..
reduce diameter exhaust to 2 inch 1st..ur engine 1.6 rite.dont use straight flowlh.its n.a not turbo maa..use 2 bullet tanabe n ending with mugen s-flow.use air filter stndard or mugen typelh.dont open one..n.a not same with turbo either u modified one..try use adjustable pulley..this suggestion to improve low end speed ur vtec..
low cost, n now see the result..n then u can upgrade slowly with ur gearbox,ecu,high/racing cam, piston,crankshaft n etc if u have more budget..try ok.gud luck:wavey:
i use b16a auto also.. with 2.0" piping with s-flow exhaust n remove cat converter,4-2-1 extractor,k&n flow plus ITR CAM.. no prob at all wit pick up n speed............................. :driver: more better from stock auto..
i think ur piping too big n try put in manual cam or high cam... can feel the diff.... :driver:
Currently using b16a manual cam, hks intake, vafc, RAM 10mm cable ,bosch fusion plug, 2.3inch pipe, fgk 4-2-1, remove cat, center bullet, fgk sflow muffler and also hot inazma pocket + pivot voltage stablizer...the low end speed much better then before. Thinking of changing ligthen crank pulley too. I also just bought a p2t spoon rechipped ecu but only works on manual trans :banghead:...so have to change to manual transmission only can put that ecu ! :driver:
I short low quality video to share
http://www.youtube.com/watch?v=_zm9pkhflws
Write your reply...
New Posts
