Engine Check Light On ! [Problem solved !] Broken ECT sensor !
Hi guys. I just got my Toyota Corona ST171 serviced because of engine jerking problem. Engine light will come and goes away in around 2 minutes intervals.
After repair, I changed a new distributor, distributor cap, new spark plugs, new spark cable, new vacuum sensors and fuel filter. No more engine jerking. But the engine light stills comes.
Just now I drive for 10minutes, engine light on the whole time. Then my engine stalls when I start to drive of from idle in traffic light.
Engine is 3SFE. Any idea why this happens? I wanted to reset my ECU to make sure the ecu relearns itself from scratch so that the error code goes away ..
Okay the check light is back again. After checking the ECU error code, its an engine coolant temperature sensor problem ... now trying to get it fixed by replacing the sensor .. updates coming soon :D
UPDATES ! 30/7/2010
Yoohoo ! I found out that the ECU code 4, faulty ECT sensor is correct. Just now went to my workshop to change the sensor .. now no more problem
:proud: Bought a genuine toyota ECT sensor to replace it .. cost me RM100+ ...
Have a look at these pictures below as attached
UPDATES ! 30/7/2010
:proud: Bought a genuine toyota ECT sensor to replace it .. cost me RM100+ ...Have a look at these pictures below as attached
