DVVT problem on emanage
dcloo
kl
dude i have own a engine where runnig turbo dvvt system
i have add on an e-manage system
in terms of igination n timing can't be use/control following by the tuner/installer tell
any 1 got an idea for it?
Yes you can control ignition timing. Use settings 7 - 3 - 0. Though the RPM mapping will be halved because you are running 3 cylinders.
but now i wan install on a 1.3 4 cylinders engine
i heard that this DVVT ECU is self learning ECU soo when you tune it after that the ECU will tune it back to normal graft just like the VVTI system the same one soo you install E-manage also no use.
All ECUs have self learning feature. You can only tune zones that are open loop. If you are running 4 cylinders and 4 coils than use 4 - 8 - A.
