Bro, can put the image size bigger? Thanks for clearing things up. Why are u not more active? Haha
Anyways, I thought using parallel setup is better? And also power are evenly spread?
Because i tot if series, one bulb die, hard to diagnose the faulty ones.
It's big already what.
cvkit17
2,884
1,354
He needs a bigger screen...stupidcar, save this diagram in a file and project it onto a screen at mamak stalls haha
levin818
1,260
321
3,183
Shah Alam
Tail light manufacturer usually connect the LED in Series and Parallel connection.
Imagine the above 4 LED in series connection is consider as circuit no.1.
They will have circuit no.2, that connect with circuit no.1 in parallel.
Then connect again with circuit no.3, in parallel, then no. 4, no. 5, and so on.
---------- Post added at 04:39 PM ---------- 6 hour anti-bump limit - Previous post was at 04:35 PM ----------
It mean if one LED is dead, whole circuit (4 LED) is off.
stupidcar
5,000 RPM
5,567
850
Damn, its too messy. Cant process the info.
Ya lor, so series is quite bad.
I will just get a 100ohm 2W resistor?
levin818
1,260
321
3,183
Shah Alam
Series connection has good power efficiency, while parallel has a terribly low efficiency.
(Imagine power wasted as heat at the high wattage resistor)
Also, series connection has more even in light intensity compare to parallel connection as what you does.
stupidcar
5,000 RPM
5,567
850
But then if I need to do 80 leds, can series manage it? 12v is not enough right?
eloo c-foos,
Thinking of transplanting engines for my waja.
Just need to know which one should be more suitable
Between evo4 or MIVEC 1.8 RS.
2. How much would the half cut costs for both engines.
3. Which is a good workshop for transplanting engines in KL?
4. Any issues to get JPJ endorsement for Evo 4 in Waja?
5. The power for both engines. Which is more beuty in terms of "Fast".
:driver:
