dashboard vibrating ...
eric_ho20
Ipoh
to all ZTHian ,
im drivin a 97' stock wira n when i reach almost 100km/h , my dashboard starts 2 vibrate ady . at 1st i dun k la , i tekan until about 150km/h then my dashboard felt like wanna pecah la ( like earthquake la ) . if i din tekan da peddle , da dashboard stop vibrating n as i tekan da peddle again , it vibrates again . need help here . thankz 2 all ZTHian ... :(
no tekan means when idling time or what?
ratling from 80 km/h till to speed may due to crook rim or swollen tyres or unbalance tyre thread
try rev till 6000 rpm when idling...if no rattle..means something wrong with tyrs,rim,driveshaft or those internal stuff
i lepas da peddle 4awhile after i reach 150km/h , n i found out dat da d/board stop vibrating ... as i continue tekan , it vibrates again . erm , do i need 2 do alignment or balancing on all da tyres ?? btw , it starts 2 vibrate after 90km/h ... im very sure bout it ... hehe :D
not related with allignment lar...
let go gas stop vibrating?
hmm...
engine bush or driveshaft maybe...
maybe ur tie rod....
too many
bro.....70% is your driveshaft problem edi....last time my friend wira also like that .....reach 100km/h and above the whole dashboard is vibrating like hell man.....(if wrong dun shoot me k)........ :D :D :D
wah :o ... so serious ar , i juz change my rear wheel bearings , front wheel ... dunno wat shaft la . after changing all those things , dis vibrate thingy onli appeared la . b4 dat , i tekan kaw kaw also ntg will happen lor . die la like dis , where got so much cash 2 settle la ... :(
norika_sakai , wat u said was true la . it realli happened 2 me . if realli da driveshaft thing ... how much will it cost huh ??
how much will da driveshaft thingy cost la ?? ... tension giler man !! hehe
ok bro , but after i change those stuff dat i stated above ... dis vibrate thingy onli appeared ... erm , i still need more explanation ler .any1 may share their xperience wit me ya . neway , thankz alot ZTHian especially 2 typicalguy ... :D
New Posts
