EG8/EG9 bumpers same only, but usually EG9 come with foglight, plastic lip, while eg8 bumper kosong only.oooo.. okay...
mine is an eg8....
so i'll try to find eg8 bumpers la.. thnx...
eg6 or eg9 oso very nice, but if wan spoon lip, eg6 is a must...arturo, well i think my prob is the same as yours. the screws n clips are damaged i think. im not sure how it happened. probably because of old age. however, i dont have the equipment or know how to fix it myself.
im actually going to the workshop to fix my car body since it was involved in an accident a few years back.
the left front tire exploded and therefore dented the chassis. so i thought to replace the bumpers along with repairing the dent.
jin, what do you think if i use eg6 bumpers. more choice for carbon lip ke?
i want to make it look aggresive.
if wan eg6, must change fenders also ke?eg6 or eg9 oso very nice, but if wan spoon lip, eg6 is a must...
EG6 fender must combine with your EG8 fender.. because the turn signal for EG6 is shorter, and if you want to use EG6 turn signals.ok. will do...
eg6 front bumper n fender
eg9 rear bumper. got it.
thnx.
when u say combine eg6 fender with eg 8 fender,u mean weld them together or what?EG6 fender must combine with your EG8 fender.. because the turn signal for EG6 is shorter, and if you want to use EG6 turn signals.
But if on budget, then no need EG6 fender.. just modify the the bumper mounting. at the fender only.. For me, it looks a bit cacat, but maybe not to you...
Sorry, usually if people convert, I recommend they go for the EG8 + EG6 fender modification, because they usually want to use EG6 turn signals or convert to projectors after that.
What I described is full front end EG6 conversion... means you can use EG6 signal, and if you buy the TYC Projectors/etc single unit headlamp + signal., can fit perfectly.. basically any eg6 single unit headlamp+signal can use... EG8/9, sure got gap at signal area.
So up to you.. buy bumper only, see if the look is acceptable or not, if not, then combine the fenders to convert EG8 front end to EG6.
Done before, because owner wanted to use TYC projectors and J's carbon air intake on a EG sedan.
Yes, it'll probably become clear when you put the bumper on.sory mate. i still dont understand.
nevermind.
maybe i'll see what u mean when i put the bumper on..
thnx 4 ur help.
cheers.:cheers:
Print out photo, show them, if they have clear idea, then they can tell you if they can do it or not.yeah. maybe.. i hope so...
thnx so much.
