BT stock engine got black smoke? Need advice.
Sil80-13
Hi all sifus,
My BT 5 speed engine when press fuel pedal, car not moving la.. got black smoke coming out. Is it normal for BT engine? Using standard ECU.
did u do anything on ur car ? mostly if black smoke is ur engine is running on over rich air fuel lor..did u have fuel pressure regulator ??? if yes did u over tune the pressure d ?
caleb_5375,
Previous owner install with AFC 5 button & sard fuel regulator. But he took it out. So I think my A/F setting gone.
I heard that the BT ECU is a self-learning ECU. Right? Will it tune back itself or I need to install a standalone ECU?
caleb_5375,
fuh.....black smoke came out-change to standalone.. very good!! yes please...i dunno what to say anymore:banghead:
---------- Post added 08-12-2009 at 12:16 AM ---------- Previous post was 08-11-2009 at 11:53 PM ----------
fuel just running rich. Black smoke is caused by excess fuel that has entered the cylinder area and cannot be burned completely. check for faulty equipment
Your setting must be totally out.
Go see a 20V's mechanic to set it back.
Must be 20V's mechanic, or you will have nightmare:biggrin:
ha ha ha go to standalone...to setting fuel...muahahaha :banghead:
no worries.. blacktop got black smoke wan.... it's normal... toyota runs their engine slightly richer.. but if u drive silvertop.. it's abit different.. silver smoke come out wan...
*cabut*
*cabut*
run in rich mixture is better than run in lean
if the black smoke come out, u're wasting your fuel..
fuel burn incompletely..
i read an article regarding this issue but forgot where. it seems must check so called O2 sensor (i don know either correct name or not but it's sensor with attach at exhaust) at exhaust bcoz it'll determine the fuel ratio in smoke which going through the exhaust. it'll send the signal to ecu to self programming on the correct fuel ratio.
