Brake Knuckle
audetom
read while you still can
Selangor/KL
I got some question here...
how to install charade detomaso's brake system on a charade aura...?
imagine this...
you use daihatsu charade detomaso's brake knuckle to put on a daihatsu charade aura...the problem is the lower arm...the aura one has similar to kancil's lower arm...but the detomaso's one not...
the deto's lower arm cannot put in the aura...the head (bull joint...i think...the one that have rubber and can move) are not the same...and the physical look also not same...deto/espri got somethin like triangular shape....
**lower arm for deto is the same as espri
**lower arm for aura is the same as kancil...but bigger
what i've done before...
grind the bottom of the bull joint of both lower arm and take it away...
then, switch over each other...and weld it back...
but it doesn't last very long...
can somebody/sifu/guru out there help me out...? urgently....cos my car now in a major maintenance work...engine,bodywork,body colour....semua skali lah....
**hope you guys understand what i'm talking about....
HELP ME.....
just to ask..whether can we switch our front brake system to use it as our rear brake system ah..meaning that switch our front disk brake to the rear and make it as the rear disk brake loh..however, i stil wanna remain the hand-brake to be functional..meaning when i parking..my hand-brake stil can be use loh..can it be done..thanks alot. :)
