help needed urgently,evo engine dies occasionaly
PUTRA14
Ji
121
7
5,018
BT.CAVES
help needed urgently,evoengine dies occasionaly
Recently after leaving my car to sleep for few months,I had this problem with my putra with evo engine,the car just didnt want to start,since the problem started with fuel ,i replaced new fuel pump and even fixed external mercedes fuel pump to support thirst for fuel for my engine,the problem arise after running few kilometers it gets choked as if no fuel again and dies off and i have to wait for it to chill off and start and drive again,the problem persist every few kilometers.
I have checked the ecu,the reading shows no prob,change the fuel pump twice,fix fuel regulator,change all the fueling lines but still unable to solve the prob,
mod done on engine:
4g67+4g63
skyline gtt turbine
external fuel pump (recently due to prob)
new intercoller piping (no leakage)
.Kindly do share ur wisdom,all wise sifus. I appreciate your kindness.million thanks
xMika
623
85
Selangor
Re: help needed urgently,evoengine dies occasionaly
Could it be a distributor/ ignition problem ? previous had this problem on my car as well. Engine dies off at traffic light sometimes, engine check light comes on, then hard to start the engine .. need to wait engine cool down around 15 minutes before able to restart the engine ..
kumar22mostwanted
1,562
152
HELL!!!
mod done on engine:
4g67+4g63
skyline gtt turbine
i had the same prob bout a few months back
it turned out to be my ignition coils
get that checked out
kumar22mostwanted
1,562
152
HELL!!!
ignition coil if u suffer misfiring, like running on 3 pistons & smell petrol in cabin bay.
:hmmmm: yeah that makes sense
but last time when my putra had the same prob i just left it at the workshop coz i trust these guys then they said they just changed the ignition coil and igniter box and it was fine after that
Although Michael Schumacher has seven world titles and the most grand prix wins ever to back himself up, more often than not he has been overshadowed by younger teammate Nico Rosberg, leading to calls of a rivalry between the pair that stops short at friendly. Mercedes however has decided to play along with a series of advetisements that build up...
