1992 ae101 convert to BT???damage??
jason591974
73
7
3,008
If not mistaken SVT is 145
sorry, bro., i copy from wikipedia.
Fourth Generation "Silver Top"
The fourth-generation 4A-GE engine was produced from 1991 to 1995. It has silver cam covers with chrome lettering, hence the nick-name "silver top". This engine yet again features a completely new cylinder head which uses five valves per cylinder instead of four. It uses Toyota Variable Valve Timing (Variable valve timing - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:Mergefrom.svg" class="image"><img alt="Mergefrom.svg" src="http://upload.wikimedia.org/wikipedia/commons/thumb/0/0f/Mergefrom.svg/50px-Mergefrom.svg.png"@@AMEPARAM@@commons/thumb/0/0f/Mergefrom.svg/50px-Mergefrom.svg.png) system on the intake cam, an increased compression ratio (10.5:1), and the intake system was replaced with a short manifold with individual throttles and velocity stacks, however the vane-type Air flow meter - Wikipedia, the free encyclopedia was retained, requiring the use of a plenum. The previous 16-valve head used a sharply curved intake port, while the 20-valve engine used a very upright straight port. This engine produces 160 PS (120 kW; 160 hp) at 7400 rpm with 16.5 kg·m (119 ft·lbf) at 5200 rpm of torque.
Fifth Generation "Black Top"
The fifth-generation 4A-GE engine produced from 1995 to 1998 is the final version of the 4A-GE engine and has black cam covers. This engine is commonly known as the "black top" due to the color of the valve cover, and yet again features an even higher compression ratio (11:1), the air flow sensor is replaced with a MAP sensor, the diameter of the four individual throttle bodies was increased from 42 mm to 45 mm, the exhaust port diameter was increased, the intake cam lift was increased from 7.9 mm to 8.2 mm and the intake ports were significantly improved in shape, contour and also the width at opening at the head was increased. Additionally, the black top had a lighter flywheel, a larger plenum, and revised rubber velocity stacks, and was also offered in 1997 with a six-speed Toyota C transmission - Wikipedia, the free encyclopedia transaxle. This revision increased the power to 165 PS (121 kW; 163 hp) at 7800 rpm with 16.5 kg·m (119 ft·lbf) of torque at 5600 rpm. These figures were issued by Toyota and are considered optimistic. It is assumed that Toyota ran the motor without ancillaries to inflate the power ratings, as some companies did before the adoption of the SAE J1349 rating standards in 2005. Still, the 'Blacktop' has become a favorite among enthusiasts and is used as an easy power upgrade for the early Toyota Corolla models, especially for use in the drift scene. Squeezing extra power from such a highly strung N/A engine can be expensive because of the relatively high state of tuning of the stock motor, and most gains come from higher lift cams and engine management.
ragerunner
383
65
The fourth-generation 4A-GE engine was produced from 1991 to 1995. It has silver cam covers with chrome lettering, hence the nick-name "silver top". This engine yet again features a completely new cylinder head which uses five valves per cylinder instead of four. It uses Toyota Variable Valve Timing (Variable valve timing - Wikipedia, the free encyclopedia was retained, requiring the use of a plenum. The previous 16-valve head used a sharply curved intake port, while the 20-valve engine used a very upright straight port. This engine produces 160 PS (120 kW; 160 hp) at 7400 rpm with 16.5 kg·m (119 ft·lbf) at 5200 rpm of torque.
Bro, my take is that firstly the power ratings, as stated, are a little inflated, and secondly, the engines are more than 10 years old now so wear and tear would mean that the power of the engine has already decreased by a figure.. So actual dyno figures for a stock BT would be way below 165PS or even 160PS for that matter. If you find a 160PS BT on dyno, it's definitely not stock standard.
jason591974
73
7
3,008
ic, bro, is it possible to restore back to the original BHP??? let said change all wear and tear part, 7age, can the transplant engin get back the 160 or 165 ps or go even more BHP??? not include bolt on.
jackylsp
205
Sungai Petani
my guess to upgrade the 20V to MAX BHP with NA (<200 bhp engine horsepower)
you need to spend atleast RM20K ++
A Post Every 5 Mins
Hey all! Quite new to this forum. Anyways, I'm looking for an engine transplant for my Corona EXIV. I was wondering if the 4A Blacktop (20v) could fit in my car... the current engine is a blown 4S-FL. I don't wan to transplant a 3S-GTE bcoz its daily driven car... too much power. Appreciate any help because the car is just sitting at home. Thx. This is the car.
