auto ecu
durangoes
hallo all forumers here,im just wanna asking , can auto bt ecu use on manual bt engine?
bro meg, you have problem like car jerking on certain rpm especially during normal driving? mine got this problem at 3k rpm. not sure if this is ecu or fueling problem.
ya, no problem. i also using the auto ecu on manual bt.
Anyway..Bro hon_cs, wat kind of dashboard u using now ? My car also facing the same problem like urs...
nope...
except torque dip a bit around 5000rpm, probably due to exhaust setup...:banghead:
confirmed this with my mech and William san of Trial...:adore:
if jerking around 3000rpm, test your O2 sensor or knock sensor...:hmmmm:
highest possibility is O2 sensor...
meg_omen, do u kno how much the O2 sensor and the knock sensor cost ?
someone did mentioned to me, auto ecu does not have rev cut. is true?
oohh...
already 2days change to 6spd MT ecu from BZR... the different is marvelous, far better than the AT ecu...
not sure why now, coz i didn't feel it when i tried it before... in fact it's the same ecu...:hmmmm:
rev cut increase pass 8000rpm, and playing in mid to high rpm is... shiok...:proud:
oohh...
yea...i shared this to other members, but no ppl believe..:bawling:
you just pnp 6speed ecu without change existing harness?
yes as long it's BT ecu... either AT, 5spd or 6spd ecu...
plug and play...
even better if have something for fine tuning...:hmmmm:
