B18cR block, head & wiring
cad843
403
12
3,018
Oita Ken
Bro,
Whats the differ between 96 and 98 specs for B18cR ? Can it be converted from 96 to 98, and is it worth it to convert since im using 96 spec (if not mistaken) ... and how to identify the differ between those 2
Sifus ... need advise pls...
cat77
3,865
16
Only the cams are different.....just change to 98 spec cams.......
camshaft
409
10
if not mistaken...96 use OBD2a...98 use OBD2b...
E-Tech
1,115
256
3,183
Johor
Bro,
Bro...
What do you want? More horses?
Or you want to change ecu?
Or you want abs and etc....
If ecu...why not consider OBD1, easy to get chip to match your upgrades....:biggrin:
cad843
403
12
3,018
Oita Ken
Bro...
Bro ... of course need more horses :biggrin: .... if can I want to put srs and abs also ... if I bought the OBD1 ... is it compatible with my current wiring / harness ?
Let say I'm install ABS and airbag ... is it current ECU can support?
E-Tech
1,115
256
3,183
Johor
Bro
for obd1 you just need to buys
a ecu and the conversion harness.
Rm1k.
For SRS and ABS susah.
U need all the wires and sensors plus the
control box...
Need to take out properly frm half cut and fix..
If not later many troubles...
Up to u..
cad843
403
12
3,018
Oita Ken
Bro
Rm1k.
control box...
Up to u..
Meaning that, if I dont want all the trouble later ... forget about installation SRS and ABS isnt it? Bro, very thankful for ur info given. Can recommend any GOOD wiring guy or not? Maybe can ask him whether he can do or not ... if not I just forget about SRS N ABS la ...
E-Tech
1,115
256
3,183
Johor
Bro,
buttttt your location in japan mah...
I can only recommend local malaysian pomen...
Wat is ur actual location?:biggrin::biggrin:
Here's some oldschool marathon today! Look at 2 retro monsters fighting to the top, on the proving grouds of the Fuji Speedway, Look at them battle through the high speed corners and a great dive by the driver of the Skyline C10. These people know what they are doing with their oldschool, that they ate some Mazda MX-5 and other cars along the way.
YouTube -...
