BOT (Bolt On Turbo)
sorry .. my question confuse :biggrin:
Okie..
Now I am using Garrett T25...the flange is T25..
So now I wanna install this turbo T28 Ball Bearing ..the flange is T25 also...
Mean no need change adapter right ??
How much install include oil & water system ? :rolleyes:
Ohh... won;t cost much. Existing water lines and oil lines not same meh..? I think they are the same... Double check ur existing oil feed lines and water inlet and outlet. If same why replacing them.
However, BB turbo are quite sensitive to the oil feed pressure. If too high, just add a filter on the oil feed. easy....
Workmanship installing the turbo should be depended on length.
Ok !! Thanks ! TAiko !! Your answer HELP ME A LOT !!
installing the turbo cost <200 and the steel braded host RM80-RM180 :biggrin:
hahaha.. today damn funny... install the knock off sqv blowoff for a customer... on the same day after a few runs... the blow off kong.... hahaha
replica hks ? :biggrin:
I am using replica too.. almost 1 year no prob:wavey:
Can use doesn;t mean it's ok. boost leak can reduce lotsa response that u won't feel. Try borrow ur friend's good original BOV any brands...
Tighten it according to ur set up(IF it's adjustable)...
unlucky for that fella... hahaha
Not to say unlucky. It's within the expectation> RM130 and RM700. What is there to complain.
Taiko...I got one question long time wanna ask you...
Hmm...Bigger turbo will cause the exhaust louder ??!!
Coz I saw those evo , subaru , supra ..etc.. when they start engine..the exhaust sound LOUD & NICE !! Any advice ??
Coz I plan to install Bigger turbo..hope my exhaust sound like 'em :biggrin:
There are a few contribution to the loud sound(which i call it noise). U can:-
Change to bigger exhaust diameter.
Change to higher lift and duration cams
Throw the mid box of your exhaust
Straight flow exhaust muffler
Tighten the throttle cable
Inchrease the iddling RPM, sound more aggresive.. kekeke
anyway, most of the contribution actually comes from the exhaust muffler.
Not a fan of loud exhaust. So, dun really know what brand sound loudest.
wanna louder sound .. change bigger muffler lo... :biggrin:
Not necessary. Bigger inlet diameter to be precise...
Or korek all the fiber also can....
Taiko...Actually I am using Trust PE II...inlet 3"...and I using straight flow also...2.5"....
Midbox and others box I throw away ad...but...the sound sunyi too!! not syiok ler ~!!
I hope next time change bigger turbo..and I will put wastegate too...
did anyone here try to BOT on NISSAN SENTRA N16?
I feel the car is heavy and does not want to perform engine convertion.
Therefore, BOT is the choice~
I saw from overseas forum that PPL doing that. but does anyone tried b4?
Is it successful doing that?
Last time I check out.. I have a FAKE Walbro !! the sound very loud ..can heard from outside.. when engine starting ...now i change another once...
Normally after install walbro fuel pump ...got the sound yieeeeee~~ right? like nyamuk sound....
Coz I install this walbro fuel pump + fuel return line......but dont have the sound ??? why ?!
anyone can help me ? coz i love the sound....... :marchmellow:
is it normal ?? a bit sound only....
Since u read about overseaforums and threads.... Get to know what thaey are using... Thigns should work fine.
Next is the mattter of who u wanna installed n get it tuned
I suggest go for stage 1 bolt on turbo... means..get a intercooler ,turbo(TD05)..etc...and boost 0.5bar..you will feel the power :biggrin: Dont worry bro..as long as dont overboost.....wont kill your engine..:biggrin:
want sound only rite? put relay lor
Ngeeeeaaa..... that should be the sound. Should be able to hear from outside. If u want even louder, instal an external pump lor...
Taiko. have to understand the characteristic first before BOTing la. U want ppl engine to detonate kah...? Try do that on a B18C. I guaranty engine knocks when turbo spools... Tested.
A good setup isn;t just on the hardware and how much u boost. It should comes along with software too... In this case, tunning.
Bro, i suggest u to understand ur engine characteristic as in Bore n stroke, Compression ratio, block material. If possible the cylinder top volume and availability of aftermarket product in support of ur project in our market.
then u can decide if u wanna continur with your BOT. Lot of ppl buy stuff buy stuff and ended up selling everything because project suspended for too long due to overspent time searching for parts.
u r rite~
