K20A fitted on what honda model
mysayasan
83
1,508
Johor Bahru
Which is most suitable honda model available for K20A swap.. and how much it will cost.. i prefer no adjust on the mounting and JPJ approved.. heheh sry nub here.. need help from sifu
joev8796
145
many civic can fit tat engine, i've seen on mag a lotus, mrs, eg6, ek oso can fit tat engine
mysayasan
83
1,508
Johor Bahru
eg6 and ek... 1.6 litre right.. can pass JPJ?.... which car dont need to adjust mounting.. which is the cheapest swapping for the car listed
joev8796
145
my fren wife's ek9 is using dis k20a from DC5. she din endorse. it's better u get 1.8 civic as da diff on da parts r lesser
klx
63
4
1,508
the increase in cc (from your present cc) should not be more than 30%. So, from 1.6 to 2.0 is OK. Of course gotta make sure its properly fitted etc lah. Go with a reliable workshop. After transplant, make sure inform your insurer coz if accident, they may not recognise it, different engine number.
khoo198
1,917
2,067
N9
mysayasan
83
1,508
Johor Bahru
oo 30%?... not 25% mmm if still ok.. i find a civic wihtout and engine and swap with k20a... how much for swapping and all.. any 1 got quotation for swapping k20a into a civic.. really interested here
lightningfield
2,474
126
Johor Bahru
www.ef-honda.com
if you plan to do k-swap, EG and EK are the best chassis to do so (lightweight chassis means power to weight ratio is improved). Basically it is plug n play if you use the correct aftermarket mountings like Innovative and Hasport. No modification needed on the chassis. But you must also count in other things to complete the swap: wirings, exhaust system (custom header is needed), shifter box etc..
Hasport Performance
http://www.innovativemounts.com/default.asp
some photos of an EG with K-swap, registered and daily driven.
The Black Mamba: Blissful Evening at Tung Chun Racing
LuKa
618
19
Kedah
Too much power on a heavier n bigger engine inside a light car.. will effect handling department.. prone of understerr will occur on FF car due to weight distribution is being upset... i mean if it is used for the street or track.. for drag, it doest not matter...
mysayasan
83
1,508
Johor Bahru
uhuh mostly for street use..
zac
1,347
231
Johor Bahru
Honda Jazz!!! looked cool when drive slow with proper bodykit ofcos and if ppl cucuk you then you can show them your tail lights and vtec roar~~~ js racing jazz use k24a...
Yong_5290
3,637
49
Klang
hotmail.com
tis is y the new K series is introduced...last time eg o ek put h22a sure understeer kao kao
with k20a and the amazing helical LSD...they r good in straight and also corner as good
AD_EG
6,328
231
Ipoh
K swap in EG/EK :love::love::love::love::love::love::love:
if i remember correctly...standby 25k just for parts....excluding installation...might be less...
JDM_YANG
50
20
1,508
i spent about $18,000usd to drop and built my k24 block/k20 head...need more info let me kno..btw i made 305whp 221ftlb on a Kpro on the 2.4 block
Dear All,
After missing in action for a while, i am back with some questions. Currently i am looking to build an engine for my Lancer GT 08, which bolted on custom turbo kit in late 2021. The car is running without much issues, boosting at 0.67, producing 257whp and 280 Nm of torque. The engine was tuned with safety in mind and AFR running 11.1 at full throttle. Recently i bought a used and running engine to start on a journey on building it to be a proper turbocharged engine with oil jets...
