Bro , you forgot to put in the cost :P
costing ar? lolzz...dunno still remember anot ler...
rear skirt i'm using GT rear skirt, but it's replica fiber made 1 la...
ori 1 very hard to get la...
my fog lamp is projector, original fx 1...
No wonder its look a bit differ from original.
Your car was fully mod already, what else still need to mod? Turbocharge? High Cam? Adjustable? ECU?
But i personally think if street use and daily use, it's more than enough already.
Bump:
i guess spend more than 10k already.
Hi Ivan,
You use the wagon 6 speed ecu once you changed to c160? or change later after that? Just wondering, what is the difference you might get from matching 5sp ecu with c160 and 6sp ecu with c160.
I'm currently using 5sp ecu with c160. I'm just wondering what's the benefit if I changed to 6sp ECU. Mind to share?
Thanks.
better don't count it... later you will think ' wah i spend so much for my car, for those money i can pay deposit for a new car'... thats why i scare to think about it![]()
yea...definately! my fren counted, he said his 1 almost reach 40k!! almost same modification...lolbetter don't count it... later you will think ' wah i spend so much for my car, for those money i can pay deposit for a new car'... thats why i scare to think about it![]()
Hi Ivan,
Thanks.
i think should not much different, 6 Speed ecu on 5 speed also working fine. last time my friend car 6 speed ECU kaput... Then he go to buy 5 speed ECU, and use it more than 2 year already. No problem, and no different too.
As far as I know lar...forgive me for my lack of knowledge.
The 6 sp ecu have different type too. Levin AE111 and Wagon AE101 are different. Like Ivan's ECU from wagon, you get to have AE101 Digital air-cond console that has Climate Control aka AUTO fan speed, temperature and etc.
If Levin AE111 6sp, you don't get that. Besides, the fuel mapping is different too. Can anyone done dyno using 5sp ECU and 6sp ECU clarify this?
Cheers.
i tried 5 speed levin ECU, 5speed wagon ECU, 6 speed levin ECU and 6 speed wagon ECU..
found that WAGON ECU has extra abit torque feel, but the levin 1 juz like smooth smooth driving..
then i ask my foreman, he said levin is 2 door, bodyweight is lighter than the wagon 4 door with a big boot..
the wagon ecu has different reading and data, althu u cabut out the casing, u can find nothing difference...
6sped ECU is different with 5 speed ECU,
last time i start using 6speed ecu since i'm using C56,
but that time was using BZR levin ECU,
found that, fuel consumption better, better acceleration, better respond..
other members might say..cheh! what's the difference?
it's the difference i experienced! u have to use for about 1 week to let ur ECU reading settle down then only u can feel the difference, last time when i using the 6speed ECU, i having the same thinking also...why i have to spend a few hundred to buy the 6 speed ECU for juz like 5 speed ECU???
but after 1 week, the feeling of driving it really enjoyable!
Hi Ivan,
Thanks for the the info shared. It will be a good reference for me as I'm still struggling to decide whether Piggy or 6sp ECU. Btw, I saw from Marketplace that you have a piece up for grab. Just checking out, from which car is that ECU from?
About the Climate Control, I'm not too sure too cause so far, most of the levin or trueno 6sp halfcut I encountered do not have that Climate control. Since my ECU also not from any above mentioned, it's from Levin BZG. I keep bugging Fatty why mine is different and cannot have the ori wagon/fx fan controller switch (mine modified to fit which only has 3 fan speed). He told me that my ECU doesn't support. Hahahaha....which is why i made the statement that it is related to ECU and the model where the ECU came from.
Anyway, need to check out whether it's true or not about the climate control thing. I need that cause the modded one is not good. The fan speed to the max also very low.
i wondering, it should be heavy mod already. Maybe High cam, standalone, cusco rs LSD, aftermarket ECU, aftermarket crank, and many aftermarket stuff already, and even maybe have :slug: inside too.
your foremen explanation like this also can ar?
Thanks master for guide me out here. I never have a BT, that why i don't know about this.
Hmm...thanks for the offer. I'll be away on and off recently and won't be at fatty place. When I'm back, I'll try to contact you for the ECU. But from your explanation, I lagi interested with wagon ECU..hahaha...wanna feel the torque...
Cheers.
update current look...haha!
hi frien...can u take a picture of ur car after switch on all the light.....let us open our jalan cahaya...
haha...i purposely buy from japan...
very hard to get in market plus u cant differentiate the ECU is from which car when u holding it...
unless got marking la...haha!
lanci lor... got rare bumper lor..... KNN u![]()
haiyoh ivan.. told u already to get the US side skirt mar.. looks better one... u dun racun racun me lor.. later if my bumper cannot sell i also pasang n put 4 HID.. then it will look like stadium negara already.. muahahahaha.....
hehehe.. i also purposely get one from halfcut shop... response damn kau good.. torque in the range 2.5-4k rpm.. good!!!!
My car is undergoing body work process... after front lip, side skirt n rear lip installed.. then send for spraying.. and change front n rear seat into subaru version 8 one... muahaha...
will share with fellow bros after settled.. hehehehe....
