Hi guys...just to share...
[youtube]2CC6M3kOhDA[/youtube]
Correct me if i'm wrong...
Source : wikipedia
Backfire - Backfire in an automobile engine typically results from various malfunctions related to the air to fuel ratio. Usually, backfiring occurs in carbureted engines that are running lean where the air fuel mixture has insufficient fuel. ("Running lean" is typically a sign of mal-adjusted carburetors or fuel injection where there is not enough fuel for the amount of air).
Common causes of back fires in the intake manifold are bad spark timing, or incorrect (usually lean) fuel ratio.
Video example of Backfire a hick-up during time 1:20 / 1:25 / 1:33 / 1:41 / 1:42 / 2:14 ...and during 3:05 causes an afterfire...unburnt fuel...Afterfire - Afterfire occurs in engines that have an emission system malfunction (air injection system diverter valve), exhaust leak or unburnt fuel in an exhaust system in which the catalytic converter has been removed. When a driver shifts up and lets off the accelerator, the engine has a moment of running rich or with insufficient oxygen. This causes an incomplete burn which causes the fumes to explode in the exhaust system
Source : wikipedia
..perhaps we need to install SAFC or another piggyback to get a perfect tuning to avoid this problem..:hmmmm:
