Saga / Iswara Rear Brake Disc Solution
Pumps can cost anywhere between RM150 - RM200 in halfcut condition.
Get it tested once you've got it & make sure you can return it in case it's leaky or has a problem.
Shouldn't cost more than RM200 for a VR4 double-layer servo :smile:
Thanks bro. But, if i wanna remain it all stock. Will changing OEM brake pads and skim back the disc will help a lot? My disc got a bit of rough surface. Thanks.
Today, i skimmed my disc and change OEM brake pads(MINTYE).
Some pics and a video to share.
BEFORE:
AFTER:
VIDEO: th_15082007021.jpg
LINK: kweng84/Z Pictures n Videos to share/SKIMMING BRAKE DISC - Photobucket - Video and Image Hosting
A lot a lot better already.
1 month ago, i changed brake oil. Bleed using vacuum, then use BOSCH DOT4 oil. Service the rear drums, changed new brake shoes and also new pumps.
Now, skimming and brake pads for better grip and it really works.
Skimming =RM60 with labor charge
MINTYE Brake Pads =RM45 with labor charge
hi hi good day to all proton saga or iswara driver,
i also drive 1 proton iswara sedan convert to MIVEC 4G92 DOCH, already 3 years.
Now i using all VR4 disc brake with double layer pump...very good also remember to check ur 4 rubber too.ok bye
Do anyone hav handbrake pro after change rear disc?my h.brake `tak makan` when parking at front house or the road down or up hill,foreman said the cable use long time n be long so i change the new set h.b.cable,at 1st 1-2weeks is very `makan`,but as long as use,still same,now i need to shift 1st gear to parking,cos scare my car ll `walk` itself :( ,can anyone help to solve tis pro?thx.
Hi! i have a question? is it need to be modify then disk break then only can installed in iswara aero back?
Do any model then no need to modify and just installed only?:driver:
hiih is steven again. yes u need to modified the rear drum brake.just need and use back the screw parts only is hard to explain. since u guys install the rear disc brake is better u guys change the front disc also and master pump also make it 2 layer.
1. all 4 must VR4
2. brake pump 2 layer can use 1.8 proton putra or sv4 honda accord.
3. change the brake oil to DOT 4.
IF GOT MISTAKE VERY SORRY.
1. all 4 must VR4
Okay thank you.
anyway i have 1 ppl he 1 2 sell me the evo 3 disbreak!
but i dun know ask who to installed for me?
wah EVO 3 disc brake ok can try to contact me i got foreman to help u but dun how much will cost and charge.
u from where.
steven 017-2392780.i at kl.
so bad u at penang. remember to ask ur foreman to double check all system such like brake hos and front pad and the rear pad.bye happy driving
ur cool bro... sharing methods with others does not loose money rite... i like u broo... cheerss.... eyy, can install one like above to my saga turbo arr?? u lump sump parts n labour laa of couse..
share with poeple no RUGI wat. right. if all vr4 brake now i not sure la last time the rear part brake cost me rm 700.00 plus labour and install and mod. now 4 pcs of vr4 maybe cost u rm 1k not sure better check with ur area kedai potong la.
i got 1 foreman driving putra 1.8 manual gear already install sky line brake with 4 pots front only the rear still use back ori putra.
Hey guys,
why dont you all try to get Perdana V6 rear disc brake? another solution for iswara/saga. I've my one install few months ago.
Perdana rear disc no need mod to fit in iswara rear?
What is the cheapest solution for rear disc on iswara?Transplanting 4G91 into my iswara and the braking system need upgrade else won't pass puspakom.:banghead:
Bump: Perdana rear disc no need mod to fit in iswara rear?
hi hi scoty how are you.... is me steven... remember or not...
the rear disc brake u can use mirage,vr4 or like our friends say perdana...
i will say u better use all VR4 DISC BRAKE AND DOUBLE LAYER PUMP... IS GOOD..
i finding solution on rear disc for saga/iswara. wad i know vr4 rear the pad are hard to get. mostly all go for perdana or waja rear disc. i wanted to get a rear disc,my drum brake giving alot problem
Isit neccessary upgrading disc brake if transpanting 4G91 into iswara?JPJ set the rules?
hi need a bit of advice, im planning to change my iswara front brakes to the wira front brakes. can i plug and play? do i have to change the brake pump and all? need advice. appreciate from the bottom of my heart :)
Bump: hi need a bit of advice, im planning to change my iswara front brakes to the wira front brakes. can i plug and play? do i have to change the brake pump and all? need advice. appreciate from the bottom of my heart :)
