just plug it on todays together intake manifold
http://foto.home.net.my/img/11966/17042007132.jpg
http://foto.home.net.my/img/11967/17042007137.jpg
Nice clutch, but you still didn't answer my question about injectors.. those are H22A injectors, but are you running the resistor box with them? Or are they the types that don't need the resistor box?
Asking because I finally found prelude injectors that don't need the resistor box, but the capacity is rather low..
So wondering what type you use on yours, so I can find the capacity of it.
without box 345 cc
with box 340 cc
if u put on the b16a/b18c sure u will overflow ur engine/petronas will be u
Loo,
You stilldon't get it, u can max out b16/b18 n still can enter class F but a original b20 cannot. sorry to those drive honda crv, b20 class C. Hehehe
But if plonking 345cc injectors in a B16A/B18C, still doable.. :P And I still can make it idle properly.. probably set the fuel regulator to some low number like 1-1.5bar or two.. :P
if 1-1.5 bar then u just keep ur car running at below 3000 rpm
or not ur car just like kancil 850/blow ur engine by ur pro tune fuel pressure on high rev
am not into h-series
h22a obd1 use 345cc injectors with resistor packs
h22a obd2 use 290cc injectors
but the funny part the latter model h22a type-s uses 340cc injectors.
from the net :
4gen JDM Prelude H23A non-vtec are 290
5gen JDM Prelude are 290
4gen USDM Prelude are 310cc
4gen JDM Prelude are 340cc
now im confused too.. ha ha ha
Blox Racing manifold. Same design as Skunk2, quality wise is quite good. I opted for this one because the new skunk2 slapped one big rice badge on top.![]()
http://img140.imageshack.us/img140/5273/08102007216ye5.th.jpg
http://img130.imageshack.us/img130/4923/08102007219xj7.th.jpg
http://img251.imageshack.us/img251/9687/08102007220cv1.th.jpg
haha, because the badge is so damn huge, almost covered the whole top part of the manifold.![]()
The top part near the throttle body engraved "B", that's the difference between type R. But design and runner length all identical.
Yup, installed on my car together with top fuel intake. Sorry no dyno here, but with butt dyno I would say 6k onwards got some difference.
Width size? See it yourself:
