Project Kancil Moderno with EJ1000 TD04L
I'm using Injectors from Supra 1JZ running 355cc. With the Sard High Performance Fuel Pump run at 265L/hour.
For Boost, I will using Greddy Profec B Boost controller set at 1 bar for daily use, and 1.8 bar for drag use. Let see when this machine being send for dyno soon.
ah nice, the 265lph fuel pump seems quite an overkill for the 355cc injector unless you got it at a good price or there is not much price differentiation. Feeling excited for you, looking forward for the dyno run soon!
It was my dream since long time ago. Even thou kancil is a small car.
It is many car enthusiast's dream to have a project car, we're all rooting for the final product. :driver:
Thanks man. Actually the fuel pump is for future upgrade on the injectors. Stage 3 probably after 3 months when this project finish. Need to make sure the engine running without any problem first.
what would be considered stage 3 upgrade cause anything after stage 2 seems abit blurry to me:biggrin:? What larger size injector are you planning to run next?
I planned to upgrade the intake manifold, throttle body, High Camshaft, Crank Rod, TD05, Larger piston 73mm.
Crank Pulley and Kevlar Belting applied. Engine also on the new painted frame with new bush mounting.
Engine Bay painted with Candy Orange. Applied 2 layer, got another final layer need to be spray, liquor and lastly polish.
Its too clean and i believe its a sin to have oil stain on an engine that clean.
One more mod that will complement such clean engine is wire tucking.
Maybe can clean other part such as the wiper motor and brake servo.they look out of place as other part are too shiny.
Reminder : Do not pop open your hood under the sun, plane might crash.tq
Probably need a transparent bonnet......lol
becareful with avs spark plug....
it is better you go for ngk or more common reputable spark plug... there is case avs iridium tip gone missing/melt/snapped and fall into combustion chamber
AVS from where? I google some say Japan but no website. Only seller's fb, Mudah and LYN......lol
Wait why aren't you doing all of this now since your engine is out? Forget about all this stage stage business and go straight to the final product. I don't understand why people want to bother with stage 1 2 3 4 5 when you should just go to 5 direct. Anything inbetween is a waste of time
Wasn't AVS right? It was Br*sk brand that had those issues I thought?
Feel the power, then when get used to it, mod some more.....hhahahahha
With mass production, some will bound to have some problems, right? Cannot be all no problem. One of my Denso Iridium the ceramic broke off, probably got blown out as cannot find in combustion chamber
Looking at how 'virgin' the engine and engine bay looks, i agree with u 255%.
Everything looks shiny and new! Anything done to the car interior? Dashboard, seats?
Looking at these project car thread really makes me wanna start on mine soon... already have the full list of items and quote but gotta take some time to save up :laugh:
Bro, my mechs advice to me to go by step as the base engine is not a turbo engine but NA. Bolt On needs to go by steps as the engine might not to be able handle the boost and power produce. Cannot simply push to the limit as the risk of engine failure is high. When the engine system running stable with the boost and power, it can be upgrade higher but accordingly.
Yes..all has been plan not only technical but interior aspect. Now we are focusing on the technical. Interior might start after the bodyworks and painting is done.
