RvR 4G63T engine dies off when comes to a stop
cfphoon
1,857
6
kuala lumpur
Hi guys. I'm having this problem with my engine for quite some time and I still can't resolve it. I'm currently running a standard Mitsubishi RvR 4G63T engine in my wira and the problem is the engine often dies off when coming to a stop while running with the AC on. Without on AC will dies off also but not that frequent. Recently just replaced stepper motor but still the same. Anyone faced this problem before?
parakey
1,367
226
Is this manual or auto? Engine stalls when you're braking down from a fast speed, right? When braking from a slower speed, it doesnt stall?
cfphoon
1,857
6
kuala lumpur
It's a manual. Braking slow speed is fine but recently I noticed that the engine stalls too without on ac. Coming downhill to a stop would make the engine stalls too
I'm not an expert but when we brake to slow down, couple of things happened at the same time;
1.Throttle body closes as we lift off the gas
2.Brake servo uses the vacuum from the intake.
3.RPM drop which causes alternator current supply to be lower.Alternator works like the dynamo on our bicycle,the faster it spins, the higher the amp it produce.
I would take a look at the vacuum hose to see if there is any leak, then check the alternator if its supplying steady current at low rpm, then the air flow sensor.
parakey
1,367
226
What he said :emoji_point_up_2: .. but also check the grounding as well
cfphoon
1,857
6
kuala lumpur
I'll definitely check again on the vacuum hose but I doubt it got leak.. How to check the air flow sensor?
Easiest way is to swap the sensor or using a computer scan tool.
Hard way is to use a multimeter but u must know the normal figure first,which most of us dont know.
When u are stationary with aircond on or off ,have u tried pressing the brake pedal multiple time and does it affect your idling?
If not then i suspect its poor wiring contact which include grou ding. Can happen.
Yup, current load, vacuum all play a part. Mine last time with air con off is ok, but with air con on it drops until very low rpm, and sometimes dies off. Change FICD work a while then FICD konk again, seems common problem. Then add manual ficd from kembara, modded it on....lol
<img class="alignnone size-full wp-image-30524" src="http://www.zerotohundred.com/wp-content/uploads/2012/06/usain_gt-r.jpg" alt="" width="600" height="338" />
If one were to give a wild guess on what car does Usain Bolt drives, it is most unlikely to be a small and slow car that does a 0-100 in a month. Being the world’s fastest man with a lightning-speed 100m dash record of 9.58 seconds, the most logical car that fits his image is the one that brings a resemblance of himself in the...
