Engine Die Off Occasionally When Stop
Sometimes it could be air leaking around the hoses joints between t/b, afm , intake manifold gasket anything after the afm. Have u check them yet, this is a tip from the TC guys. Just my 2 cents.
Still haven't rectify yet... but the frequency of the engine die off much lesser after I vroom....vroom.... at 4k~5k rpm in highway..
No error code so far... so quite reluctant to change afm yet.
Could it due to the exhaust pipe stuck with carbon?
Don't think its the exhaust as the only vehicle i've heard having carbon stuck in the exhaust was a kancil (ori piping too small). Have you de-cat your exhaust yet? , cats have the tendency to get stuck when too much carbon exiting out of the exhaust (incorrect air/fuel mixture or running too rich).Sometimes, your diagnostic scanner cannot detect a problem if it is not sensor related. I would suspect either the throttle position sensor, Maf/AFM or one of the hoses joint or manifold gasket is leaking air. What about idling? Is it coughing or having smooth idle . Our felio should idle around 500-600 rpm quite smoothly, otherwise something is wrg already.To check the air leak from the maf till the inlet manifold (upperhalf) try spraying some carb/throttle body cleaner sparingly during idling of the engine. CAUTION: DO NOT SPRAY DIRECTLY ON ANY SENSOR OR CONNECTORS. Just around the hoses gaps and inlet manifold gasket. If there are some leaks the RPM would suddenly surge. Then u have detected the leak! Try something cheap like this b4 deciding on any components swap.
Lawcc,
Can u pm me the place where u do engine diagnostic and can turn off the coil one by one cos I'm having the problem of car losing power and RPM cannot ram high. I suspect one of the coil is having problem.
When press the fuel pedal, the engine difficultly wroom...wroom....and no power. Just change the spark plug today but cannot solve the problem. Sometimes OK some time not OK....also go to disgnose engine but they cannot switch off the coil one by one. Please pm the contact when they can do that.
Thanks in advance.
Hope to solve it fast cos it is very fuel consuming.
i used my own diagnostic scanner. this one can only be used for old socket type (model 96,97).
Lawcc, oh I see, too bad. My A32 is year 2000. hai....ya......
Any one have any idea where to find one, otherwise will need to go back to TC to diagnose liaw....
Lawcc,
Thanks in advance.
I believe that a engine diagnostic scanner can do a power balance test between the cylinders to detect problem cyclinder with a low compression compare to others. Or you can swap between coils to detect the dead or weak coil.
Hi Lawcc,
Has your 'Engine Die Off Occasionally When Stop' problem resolved? I am facing exactly the same issue for the past 4 months. Sent the car to my usual workshop and TC, replaced IACV (used) clean TB, cleaned AFM using CRC Contact Cleaner, clean filter and so on..the problem is still there. Almost give up already..helpp
Care to share your solution?
Hi Lawcc,
Welcome to the VQ headache , hehehe. A32s r generally very smooth and comfortable car to drive eventhough the engine technology has been around for more than 10years already .Its considered quite technically advanced during its time coz u have the Mevi system (variable air intake manifold and not the MYvi!) variable timing control (earlier models which was dicontinued due to noisy timing chain or something) and all aluminium block and cyclinder head. The pistons r made of light weight material known as molybedum to reduce fuel consumption and increase performance as compared to VG series. Its known to have a bullet proof bottom end.
However, the said engine also have some hard to solve problems such as rough idling , engine die off, hair tearing electronics gremlins and oil leaks from various parts of oil seals such as flywheel oilseals,etcs. These kind of problems cannot be solved immediately but u have to patiently trace it to the root of it. One sensor problem would create a chain of other problem for the engine. If u r lucky, problem would be solved by plugging in consult scanner. If its non detectable by the scanner , then it could be some intermittent wiring problem. Thats when our local mechanics start to dissappear, hahaha.. Just my 2 cents. :banghead::banghead::biggrin::biggrin::driver::driver:
ahloy,
I clean TB, IACV, AFM etc can't solve the issue.
So unreluctantly replaced the AFM from chop-shop for RM250, thank God so far never happen again. Never thought AFM is an issue as no engine light on or error code detected.
Nice..good for you! I am reluctant to change the AFM too because no error code detected. Furthermore, i have tried using AFM from another good running Ceffy in my car but the problem still happen.
Anyway thanks Lawcc, this news is hope. Do you happen to know whether the same chop shop still has another AFM unit for me to buy? Or PM me the number pls.
My mechanic got it for me. If you want I can give you his contact. But we are in PJ leh...
You may also zoom in in replacing the IACV too. BTW what is your mileage?
ahloy,
Lawwcc,:wavey:
Glad u have nailed the problem in the butt.. I think its no use cleaning the AFM. Some AFM r self cleaning i guess. U did not change the injectors meh?
I have changed the IACV (used). Mileage is bad now, RM50 gives about 170km (before could give about 200km).I will try changing the AFM anyway, will look for the AFM in chop shop myself.
My car is also jerking sometimes. Feel like power loss and engine hesitate when pressing accelerator, difficult to vroom vroom. Sometimes when moving form stop by pressing pedal lightly, i can feel power hesitation that I need to press pedal hard to feel the power. Previously we just need to tap lightly to make the car surging forward (hmm nice..) Could this due to coil or injection? Lawcc, did you experience the same before? Ming Fei, have you solved your problem?
ahloy,
I had changed all the ignition coils (6 nos from chop shop...make sure u see them dismantle from the halfcut directly.....and not loose unit from their store.....because it may be the trade in units) since 2 weeks ago, the jerk....jerk....jerking problem and power lost never occur again since then, but still monitoring the progress. Hopefully that is the right solution.
But Fuel consumption still very high, about 7km per liter only :mad::mad::mad::bawling:(RM0.33 per km).... looking into changing all the sensor from chop shop.... still searching.:idea:
Hope this will help
