Should not be, maybe mechanic use wrench to tighten.....SC use machine?
Tighten until too over. Perhaps a wrench like you said.Should not be, maybe mechanic use wrench to tighten.....
Unless it is not tighten can loosen but if tighten properly, removing will be easy. If over tighten, removal can be hell. Have seen people driving a screw driver right thought the oil filter to remove it....Tighten until too over. Perhaps a wrench like you said.
Oil filter wrench will do. Using screw driver might assumed thread is makan dy.Unless it is not tighten can loosen but if tighten properly, removing will be easy. If over tighten, removal can be hell. Have seen people driving a screw driver right thought the oil filter to remove it....
Sometimes have to use screwdriver when it's overtightened until oil filter wrench is slipping while removing it. So far only needed to do it onceOil filter wrench will do. Using screw driver might assumed thread is makan dy.
i use chain type oil filter wrench for difficult filter.most of it comes with very short handle so it can fit and turn in tight space. Handle is short but so far it have never failed me.Filters which are too tight will crumple but wil turn and able to be open.Sometimes have to use screwdriver when it's overtightened until oil filter wrench is slipping while removing it. So far only needed to do it once
Yours not tight. Have seen at mechanic even using the chain, the filter got twisted and crushed, that is why the screw driver right though it method to remove......loli use chain type oil filter wrench for difficult filter.most of it comes with very short handle so it can fit and turn in tight space. Handle is short but so far it have never failed me.Filters which are too tight will crumple but wil turn and able to be open.
Been in that situation before. wrench could not help. last choice hammer it with screw driver and turn it.Unless it is not tighten can loosen but if tighten properly, removing will be easy. If over tighten, removal can be hell. Have seen people driving a screw driver right thought the oil filter to remove it....
