SATRIA 1.6 - Seeking advices for TUNING & UPGRADES
Bro. slipar also Wira and Satria kaki......lol:biggrin:
He join us for TT before and his wife drive the Satria on 205/45R16....don't play play.....hhahahhahah:burnout:
Looks like Wira kaki is still popular. :biggrin:
205/45/16 is the size for Wira SE stock wheels isn't it? Won't that be heavy, but that depends whether the Satria is on 4G1 series or 4G9 series...
But 4-2-1 extractors are safe, Plug and play for wira....:biggrin:
Really? If 4-2-1, no need to worry about radiator fan clearance?
D stock fan is d bulky one rite?so I guess changing to d slim aftermarket ones shld solve d clearance issue..at least that's what I did to my 4g63 Wira..I x have to shave off radiator housing or whatever..n I was using banana manifold wiz wastegate summore..
I think it is the bulky one? Not sure which one are you referring to. Mine is a 4G15 manual, so I have a smaller radiator with its own fan, and another fan for the aircond unlike the automatic 4G15 which uses a larger radiator which looks like it is integrated together with the aircond fan.
The 4-2-1 is less bulky because start at 4, it joins to form into 2, then down to the bottom and joined to 1 before the flexible bellow. The 4-1 have 4 pipe all the way, so will need much more space.....:biggrin:
Looks like I shall ignore 4-1 then. I want to ask, after 4-2-1 is installed, I know it helps in lower to mid rpm range, but then how about high rpm like around 5k to 6k? Will the power at least remain as good as stock or even worse than stock?
I do like the feeling that the car gives when it goes over 5k rpm. :biggrin:
The extractor are right in front helps to the front end. You still have the whole exhaust system to think about. Like bro. Littlewhitewagon mention if not doing other mods somewhere it will still get stuck. You free the front then as you revs goes higher more exhaust gas need to clear and say you maintain the same pipe and muffler at the end it actually slows the whole system....:smokin:
That means I probably need to do the muffler as well... If is straight flow, it will be noisy. Not a good idea for now as I don't want my family to know that I am modding the car without them knowing. :rofl:
You need the one with the valve, open become straight through at high end......lol:rofl:
