You change radiator again?Thats why im running preve radiator loh!
That's the one we changed last time.You change radiator again?
How is the water in the radiator now? If rusty, of course flush loh......Din't do block flushing last time. It was more than a year ago. So, is it necessary to flush out rust from the block?
Sorry to hear that mateNo choice
Need to overhaul.
The car was at 160kmph with a 4500RPM.
I felt something was wrong, i know now.
Not as rusty as before fixing the stuck problem. Slight rusty water.How is the water in the radiator now? If rusty, of course flush loh......
with 4-1 u must consider extractor to ground clearance also..Now you are making me doubt whether should I even change the extractor since you say it is quite pointless. After reading what you write, it looks like 4-2-1 is the better choice than 4-1 then?
That could be a problem for me. For now, my car occasionally scrapes the floor especially for the front tow hook.with 4-1 u must consider extractor to ground clearance also..
Why is it so low?That could be a problem for me. For now, my car occasionally scrapes the floor especially for the front tow hook.
One of my group member already kena. Lowered and with 4-1 exhaust header, scrap the curve end of the 4-1 pipewith 4-1 u must consider extractor to ground clearance also..
That's very true..i never thought about this before i bought my extractorwith 4-1 u must consider extractor to ground clearance also..
:shot::shot::shot:One of my group member already kena. Lowered and with 4-1 exhaust header, scrap the curve end of the 4-1 pipe
how did you managed to scrape the front tow hook??That could be a problem for me. For now, my car occasionally scrapes the floor especially for the front tow hook.
kapowwwthat's very true..i never thought about this before i bought my extractor
:shot::shot::shot:
Not so sure. The tow hook is the one exactly below the front bumper isn't it?Why is it so low?
Sent from my SM-G900F using Tapatalk
Any serious problems if one of the pipes broke?One of my group member already kena. Lowered and with 4-1 exhaust header, scrap the curve end of the 4-1 pipe
Two different mechanics told me before about the radiator fan clearance issue. This is the main reason that cause me to think whether should I change the extractor or not.for road use better opt for 4-2-1..ground clearance ok..installation ok..
but be carefull when choosing..certain brand got issue with radiator fan clearance also..discuss it before in this forum..
Coming down from slope or speed bump.how did you managed to scrape the front tow hook??
Yeah. But mine is lowered and I'm not scraping yet. What have you done?Not so sure. The tow hook is the one exactly below the front bumper isn't it?
serious ah? that's like your front suspension problem or you went over speed bumps at high speed.Coming down from slope or speed bump.
Yeap other than ground clearance, you will need to consider that too. When i install my extractor i have to grind abit of my radiator fan housing as well...Two different mechanics told me before about the radiator fan clearance issue. This is the main reason that cause me to think whether should I change the extractor or not.
Old suspension bottoming out maybe...Yeah. But mine is lowered and I'm not scraping yet. What have you done?
Bro. slipar also Wira and Satria kaki......lolThat's very true..i never thought about this before i bought my extractor
:shot::shot::shot:
But 4-2-1 extractors are safe, Plug and play for wira....Two different mechanics told me before about the radiator fan clearance issue. This is the main reason that cause me to think whether should I change the extractor or not.
