Nope it won't last for 2 years I think 1-1.5years...
U mean if after 2 years will more new tire?
Gauging your mileage.....hahhahhaha
Hope they start bringing in many sizes....
Hope they start bringing in many sizes....![]()
I think with 50K mileage no problem mayb can up to 60K mileageThat Hankook has 500 tread wear rating so it should last very long if normal.
Haha...me average 38-42K mileage per year...but I din use the tire until botak,I use until reach warning line of nearly warning line then I will change tire already and the old 1 let tire shop trade in back...
Ya...really hope they bring many many size in Malaysia....hahaha
---------- Post added at 03:07 PM ---------- 6 hour anti-bump limit - Previous post was at 03:06 PM ----------
Should be way more than that! I'm using F1-D5 with just 300 tread wear and it's already pass 50k km on a staggered setup without rotation. If with rotation should add maybe another 10k km. And I drive sometimes a bit aggressively also. So your Hankook should theoretically last at least 70k km or more.
Maybe can push to 2 years then, but main thing now is how the v2 concept 2 performs.....![]()
U guys pump how many tire pressure?
Depends on the car. For me usually between 32-35psi.
Usually from 30 to 35psi. 60 series above can be at 30psi and lower series more air pressure.
32psi for you is ok.....![]()
Sometimes I will pump 34psi...
34psi and 32psi which 1 more suitable?
If want lap high speed is 34psi better?
Icic..I always pump all tire with same pressure
---------- Post added at 06:29 PM ---------- 6 hour anti-bump limit - Previous post was at 03:42 PM ----------
Front tire pressure higher than rear tire will better than 4 tire same pressure?
Because the rear carries less weight, I find having same pressure all round, the rear are bumpy, that is why I use lower pressure for the rear. But that is me, if you find it okay just carry on. That is why I mentioned play around with the pressure and find the best setting that suits your driving style....![]()
how much is the new v12 215/45/r17? im currently on v12 205/40/r17 bought last year for rm250/pc at ban hooi (doubt can still get tht price lol) but botak liao
