DIY - Cooler AirCon for FREE
I also diy wrap the air con pipe.
already done on :
-waja
-kenari
-pajero
-exora
-blm
hardest is my waja as the engine space is very2 tight.
longest is the pajero and the exora as its equipped with rear blower.
i used the same material but i bought it in long sheet.4 feet wide and i cut a long piece then wrap is around the pipe.
the insulator is also used as sound insulator on my blm.i put it inside the door panel as its hollow.can feel its quiter.
marv3
496
57
Unless it is a few layer. Anyway this tube easier, just cut the length, cut the side and slip the tube in then cable tie it.
Hard to find. The last one i had from CVkit, it wasnt the right size. So after a while, the tube open up, leaving the aircon tube expose....Anyone knows where got shop or aircon shop that sells this?
g88
3,082
54
5,148
Is it possible to use aluminum foil? Has anyone try it?
foil doesn't 'hold' cold
---------- Post added at 11:38 AM ---------- 6 hour anti-bump limit - Previous post was at 11:37 AM ----------
goto home aircond installer..they probably give you for free....thats how i got mine :p
30,002
Not the right size? You wrap the aluminum hose or rubber hose? For Aluminum just nice, rubber hose no need wrap...
---------- Post added at 01:15 PM ---------- 6 hour anti-bump limit - Previous post was at 01:14 PM ----------
Those we are using are for house air con ones......lol:biggrin:
marv3
496
57
My pipe is bigger la (sounds damn wrong). So the hose i need to get a bigger diameter so can wrap my pipe nicely (sounds damn wrong again)
:biggrin::biggrin::biggrin::biggrin:
30,002
Bro maybe u can google air cond repair shop near PJ
Not only repair but actually should be air con installer......:biggrin:
---------- Post added at 04:58 PM ---------- 6 hour anti-bump limit - Previous post was at 04:57 PM ----------
So....Does anyone know any aircon shop around PJ area? With various sizes hose??
Used to have 2 shops near my house, but got to check. One already shifted the other I am not sure..
to all sifu at 0-100.com
just asking 1 question...can i used 1.6 injection kit for my 1.3 carbie?..some people said no because different 'tapak' intake manifold...is it rite?
if i change the intake manifold to 1.3/1.5 efi, can i use 'rojak' with the others 1.6 kit such as ecu, wiring and etc?
thank u
