As the title suggest...
I just had my filter replaced. I dont buy the replacement filter but i just replace the filter material itself only. Stock filter is paper type and it restrict air flow making me put fan speed to 2 which can be uncomfortably cold for me.
Lets start
http://i280.photobucket.com/albums/kk167/gunnerzz_8094/aircon11.jpg
The filter housing is located behind the glove box.
First, remove the glove box.its held using 2 screw.Recommend u empty the glove box first to prevent the stuff in the box being scattered on the floor.
Notice the black plastic cover, remove it to.Its held using 5 screw.
http://i280.photobucket.com/albums/kk167/gunnerzz_8094/aircon12.jpg
http://i280.photobucket.com/albums/kk167/gunnerzz_8094/aircon13.jpg
The shining piece of metal needs to be removed too. Held in place using 2 size 10 bolt and 2 screw.
This is what it looks like with the black plastic cover off. The filter is located behind the plastic cover with a small black box attached to it.It is held using 6 screw and 2 clip at the bottom.
http://i280.photobucket.com/albums/kk167/gunnerzz_8094/aircon14.jpg
This one screw is a bit tricky to remove.Its either using a short screwdriver or in my case a size 8 socket wrench.
http://i280.photobucket.com/albums/kk167/gunnerzz_8094/aircon15.jpg
2 clip to be removed at the bottom. I use a screw driver.
http://i280.photobucket.com/albums/kk167/gunnerzz_8094/aircon16.jpg
This is the filter. Notice that its dirty. To remove the filter, i use my left hand to move the wiring out of the way while my right hand pull it out.
http://i280.photobucket.com/albums/kk167/gunnerzz_8094/aircon17.jpg
Yucks....
My filter is DIY and had been change 3 times.The paper clip seems to do it job of keeping the filter in place well.
http://i280.photobucket.com/albums/kk167/gunnerzz_8094/aircon18.jpg
This is the home aircon filter i use as replacement. Bought it at Daiso. Have to cut it to size.
Notice how dirty the old filter compare to the new one?
http://i280.photobucket.com/albums/kk167/gunnerzz_8094/aircon19.jpg
New filter is on. Installation is the reverse process. The 2 clip can be installed u
just using hand.
There you go...
Its simple, only 20 minutes.
Next DIY-Servicing a fuel divider of a Merc E200.
Lets start
Yucks....
just using hand.
There you go...
