MyVi Extreme mods/upgrades?
Supra_Fanatics
20,673
3,998
Hello... do you know your initial-D or not? One hand driving while doing something else is Bunta level driving man. BUNNNTTAAAA
Actually no la. The fella is pretty damn fast in the corners with that Kelisa. Brand new Trestors also run in already after that sort of drive. The fella complain after that day drive the brakes don't respond as well anymore. Sounds like the pads cooked or overheated! No wonder that day those cars following behind him all complain super brake stink!
There is, the movie Takumi using one Hand :smile:
I'm a slow driver la. The real uncle speed.
Brakes bedding in that's why stinks haha!
Is like following the skunk :rofl:
Btw, I think my pads on the left might have worn out :rofl:
Yesterday brake got "Krok, Krok, Krok sound" :stoned:
But funny thing is that the sound is only on the left. Is the same part where before I change my pads and skimmed the disc, it has the yiiii sound.
:confused:
Wow! imagine what he can do in his Jetta then......:smokin::rofl:
Supra_Fanatics
20,673
3,998
Jetta I have to get rid of the sampan bodyroll and improve the handling only can. :rofl:
Takumi is now driving with one had after stage 4 right?
Also, Bunta drifts with no hands. :thefinger:
I'm not quite sure...Bunta don't use hands? Maybe when lighting cigarette la.
LucasChng
113
27
DELETED
:confused:
I have the krok krok sound everytime I touch the brake pedal. Found out the problem, the brake pad locking /sitting point area sort of loosen due to friction or smth.
calvin.sio
24
4
1,503
Singapore
If I were you, I'd change k&n drop in air filter, high low soft hard adjustable, 16" sport rims and the muffler 1st before going for further mods.
dear TS,
its a Myvi so the handling is like a boat.suspension is also all over the place.not even good enough for normal driving.let alone the 1.5 engine.
i would suggest u improve the handling first.u can install some bars.front upper,rear anti roll.
drive it for a few day and feel the improvement.
if u still dont feel confident in it which i know i wont,get a decent 15inch rim and shod it with a good rubber.
drive around again for a few days.stop modding the handling dept if u are satisfied.if not then u need a better suspension.u can go for adjustable set but if u get the rate wrong then it will be soo hard that i wont bother to get a lift on yr car to work even if its free.
sport spring?u need to match it to a set of sport absorber too.a set of sport spring+sport absorber is alwasy cheaper than a set of adjustable.
if u still not satisfied then my friend,u are buying the wrong car.
the engine is powerful enough but if u insist then go for a drop in air filter.then u might want to use a better front brake pad.
also,get a decent set of speaker and if the sound still like a funeral then get a decent head unit.notice that i left out amp?
its because a decent head unit paired with decent speaker and set the audio parameter properly can surprise others with amp.
issuzark
861
66
dear TS,
Don't think he needs to get better front brake pad if all he does to his engine is add k&n drop-in.
for the feel good factor...hehehehe
if he drive like how i do last time,even stock engine will require better pad.oe pad just cant cope with the heat generated from late braking and will have uneven wear on the disc.
Yup, better stopping is always way better then cannot stop.....:rofl:
If the GT-R signifies Nissan's Innovation, the 350z signifies their heritage, then the Silvia (or the 240sx or the 200sx or the 180sx) is the model that signifies their youth. Since the famous (relatively) low cost FR sport coupe ended production in August of 2002.
(artist rendering, not actual car, by Best Car...
