https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-xpa1/t1.0-9/10390148_10204135244281011_1197861050089002343_n.jpg
Anything to be concerned of? :hmmmm:
if the part is cheap must as well change it since u have taken it out.
any symptom your sensor already kaput...??
O2 sensor and cheap do not belong in the same sentence...![]()
O2 sensor quite sensitive wei. You take in and out all the time something will break. Then fc bad and all that lovely stuff associated to a broken o2 then good luck
Nothing wrong pasang back.....![]()
Only once to check..
Ya lo...to me it feels okay
Sent from my Xperia TX using Tapatalk
Should we clean it in like how many thousand KMs? Or only use till it kaput lol.
Never heard of cleaning them. Probably can try if the error code say O2 faulty, then can take out clean and put back to try. If don't work, then have to change...![]()
) for about 24 hours..Along the lines of soaking it in gasoline (do we have that here in Malaysia?) for about 24 hours..
If got error code drown it in gasoline also can, but not when no error code.....hahahhahahha![]()
Hand dont itchy itchy go damage something![]()
That is why no error code don't touch it......![]()
How to check if oxygen sensor is faulty ??
Your assistance is highly appreciated.
Thank you
...now..it's time to thank for a good work done by Kit and his crew...Well, I have to...
