Too many and all claim to be the best or No.1....so confusing![]()
Well, if you are selling your products, would you say your product is behind others or are No:10.....hahahahaha
Self claim is no claim.
Self praise is no praise. LOL
For me, no need to be confused, just stick to trusted well known brands like Mobil, Total, Shell, Castrol, etc2 and follow regular maintenance schedule and you should be fine.
Hmm.. My fully syn Pennzoil 5W30 seems to do quite poorly if the car is stuck in slow heavy traffic for more than an hour. Once it's heated to that extent the oil seems to be overly thin and doesn't do any favors for my car. And it's barely 2k km since I last changed.
Dammit.
Butt feel? Or u checked the oil?
Dammit.
Dammit.
Dammit.
Not the hotter it gets, the more viscous it is?![]()
So don't use penzoil? Lol
Hmm just like Bardhal I guess. Izso, 5w40 next try? Maybe will not become so thin? Haha
I don't know man. On my other cars they happily working but on mine when stuck in a jam it starts to feel like I'm running water in the engine rather than oil.
Hmm.. I might consider that. But I'm quite scared to do that especially since my engine has had a lot done to it. Don't want it to start leaking all over the place again.
Doesn't work that way. The oil is at optimum viscosity when at 100 degree Celsius, meaning it's maximum viscosity is 30 weight at 100 degrees C. At that time my meter was telling me the oil was at 98 degrees C so that's close enough to the 100 it's supposed to be at. It didn't feel so good at that temp. I would hate to imagine what it'll do when I go on track and heat up the engine even more. I think I might drain this Pennzoil soon and try something else. I wanna go to that ZTH TTA in Nov!
5w-40 is thicker, so why scare leak?
Yah! better test which oil your hero like before your TTA, and that goes for the Blue Advantage also. Better test and see whether it is better then the Bendix semi that you have now. Since for track no issue with cold bite...![]()
So choosing an engine oil also is very important if wanna track I suppose. Like later engine heat increase like u guys said. :hmmmm:
Then what's best engine oil recommended for track? TRD? :hmmmm2:
Higher viscosity won't really work with my car. I've blueprinted, lightened and balanced my internals. My friend calculated or something that I should stick with 30 weight only. More than that and I might risk screwing up how little tolerance my engine internals have and break something.
I just got my rear caliper tool today, so I finally can DIY the install for the Trestors.
Well, whatever oil you use it's important you just make sure it's able to take the beating you're gonna give it on track otherwise expect premature break down of the oil and less protection for the engine. I'd use something else other than Toyota oil since Pennzoil OEMs for them. I'm scratching my head on what oil to use. Sigh.
I just got my rear caliper tool today, so I finally can DIY the install for the Trestors.![]()
If u have the budget maybe can try chemlube racing. Used once, really not bad. Usually I just use the normal Chemlube fully Syn. After using CL Racing, kinda obsessed. Car is really smooth and responsive. :top:
Cleaning addictive in it is good as well.
Oh! if your hero internals are that tight better maintain 30 weight and probably POA or Ester base oil then....
When DIY your brakes?....
---------- Post added at 03:28 PM ---------- 6 hour anti-bump limit - Previous post was at 03:26 PM ----------
If not mistaken, read some where Racing oil are just use for that race then the oil is changed. Not to be use like normal prolong use for 5k or 10k km....![]()
Damnnn. A modded 1.5 MIVEC also mau high maintenance okay. Hahaha
KY, ur driving environment very different than Izso's. Wahahahahaha
so your result might turn out differently if its revved til redline most of the time.
Then that engine oil is even more suitable.Oh! if your hero internals are that tight better maintain 30 weight and probably POA or Ester base oil then....
